Does your's have a "light", or the glowing "pig tail" wire in a viewing port? If it's the latter, more than likely the wire has burned through or broken and "0" current is going to the glow-plugs. You can by-pass the indicator with a jumper wire to the glowplugs, but only momentarily as the wire is also used as a resistor
