LB1914 friend left key on_hour meter 400 hours later
   / LB1914 friend left key on_hour meter 400 hours later #1
hz293
Kalama,WA
Kubota B7510HSD
Anything I can do here. I've got 400 hours more than the tractor should have because a friend left the key on. Now instead of 212 hours I've got 616 hours. Help.
   / LB1914 friend left key on_hour meter 400 hours later #2
Short of replacing it and running up 212 on the new one, I have no other suggestions. An extra 400 hours is not a real big deal in my mind..
   / LB1914 friend left key on_hour meter 400 hours later #3
Yeah, don't lend equipment out to friends:eek:
But really, I don;t think you can fix this...Just have to make a note of it in your manual.
   / LB1914 friend left key on_hour meter 400 hours later #4
well.... it must be driven electrically...why can't one just disconnect the electricity?? I know nothing about the actual tractor, but this thought came to mind.
   / LB1914 friend left key on_hour meter 400 hours later #5
That's what I would do, but of course, you could do as texasjohn said; just diconnect power to the hour meter and keep track of the time you use the tractor for the next 400 hours, then hook the power back up to the hour meter. That would be too much trouble for me.:D
   / LB1914 friend left key on_hour meter 400 hours later #6
I don't see how it could have 400 extra hours on it.
The battery would go dead way before that.
Try leaving the switch on in your car for 2 weeks and 2 days .
   / LB1914 friend left key on_hour meter 400 hours later #7
I do not see how it could have 400 extra hours on it. That hour meter is driven by engine rotation mechanicly. The hourmeter on a LB1914 is not electrical. Your friend must have used it for 400 hours then. Either that or he broke the dash panel and replaced it with a used 1.
   / LB1914 friend left key on_hour meter 400 hours later #9
I agree,I left the key on my 2008 kioti Dk40se and the battery was dead after 3 hours.coobie
   / LB1914 friend left key on_hour meter 400 hours later #10
How long did he have it? 16 days and 40 minutes? Maybe he let it run the whole time 24x7 :rolleyes:
84'' Bucket (A47384)
2016 Ford F-450 Ext. Cab Knapheide Stake Body Flatbed Truck (A50323)
2016 Ford F-450...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
14' Bi-Parting Gate (A47384)
14' Bi-Parting...
2012 Ford F250 Pick Up (A47384)
2012 Ford F250...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
