LB 2204 oil and filter recommendations
/ LB 2204 oil and filter recommendations #1
RYDHD
Kioti LB 2204
Hi, new to the group and new to owning an older tractor.
I have a Kioti LB 2204 I want to change the oil and filter, just don’t know what to use. Also should I run additive to the fuel, I live in the north east.
thanks in advance!
/ LB 2204 oil and filter recommendations #2
Start putting anti gel in your fuel now and treat what is in your tank currently. May not need it for another month but it wont be a problem if you put it in now. Also keep a spare fuel filter on hand.
As for oil, use the manufacturers spec weight for the temps. Oil filter, any of the US made filters are fine. Baldwin, fleetguard, luber finder, champion and I believe some of the HD fram line is us made
