lawn verticutter and seeder
   / lawn verticutter and seeder
Bully,
Yes, you were right on the older 8N Ford. I was using it for testing and moving it around in the shop. Without live hydraulics was a big disadvantage on moving it with the PTO hooked up. I had to unhook the PTO shaft to raise it and move it. And then our first test series, I used the Ford tractor, and like I mentioned earlier, Just to put grooves in the ground I was able to travel at 3 mph. Yes, you can slow the tractor speed down enough to run the machine, and do a good job. It doesn't seem to take much horse power since you are just cutting straight and shallow grooves in the ground.
I measured the distance between the tangs(teeth) - 1 5/8". Yugo
   / lawn verticutter and seeder #12
When you get ready to slit seed this fall, check out ntep.org and the tall fescue page that will show you the best seed for your area. I used to sell a great deal of tall fescue seed still have an associate in your area. Good luck and have fun making beautiful lawns.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
Enmark Z Spray (A53316)
Enmark Z Spray...
