Lawn Vac tubing
   / Lawn Vac tubing #1
raykos
Central Pa.
JD2305
Hi all,
Has anyone ever used 6" solid drainage pipe for lawn vac tubing?
Thanks,
Ray
   / Lawn Vac tubing #2
I spliced in some 6" plastic pipe parts into my system. It worked great except on really cold days, when it can crack if you accidentally pick up a rock.
   / Lawn Vac tubing #3
Haven't tried that, but I did use 6" galvanized duct/smoke pipe when I was testing my system with an old hose that was just a little too short. Worked pretty well, then i plunked down the $ for some good flex tubing from McMaster-carr that has served me well.
   / Lawn Vac tubing
Thanks for the responses.
Yankeerider, can you give me a little more detail on the tubing from McMaster-carr? Went to their web site and found quite a selection of flexible tubing?
   / Lawn Vac tubing #5
I needed new 6" tubing for my Trac-Vac. I found the local Chamberlin rubber store had a much better quality hose at a very reasonable price. and they cut it to whatever length you need. I think I bought 8 or 10 feet of it.
   / Lawn Vac tubing #6
Raykos-
The stuff I am using is on page 208 of their current online catalog. It's called "Economical Rubber Duct Hose" made of EPDM rubber. The 6" size is 7.87/ft . There's also a version with a wear strip which I didn't get. This is probably the fifth year of use I've gotten out of it, and so far no obvious deterioration.
   / Lawn Vac tubing #7
You can also special order it from Tractor Supply Company. No matter where you buy it, it's over priced.
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
