Lawn Vac tubing
   / Lawn Vac tubing #1
raykos
Central Pa.
JD2305
Hi all,
Has anyone ever used 6" solid drainage pipe for lawn vac tubing?
Thanks,
Ray
   / Lawn Vac tubing #2
I spliced in some 6" plastic pipe parts into my system. It worked great except on really cold days, when it can crack if you accidentally pick up a rock.
   / Lawn Vac tubing #3
Haven't tried that, but I did use 6" galvanized duct/smoke pipe when I was testing my system with an old hose that was just a little too short. Worked pretty well, then i plunked down the $ for some good flex tubing from McMaster-carr that has served me well.
   / Lawn Vac tubing
Thanks for the responses.
Yankeerider, can you give me a little more detail on the tubing from McMaster-carr? Went to their web site and found quite a selection of flexible tubing?
   / Lawn Vac tubing #5
I needed new 6" tubing for my Trac-Vac. I found the local Chamberlin rubber store had a much better quality hose at a very reasonable price. and they cut it to whatever length you need. I think I bought 8 or 10 feet of it.
   / Lawn Vac tubing #6
Raykos-
The stuff I am using is on page 208 of their current online catalog. It's called "Economical Rubber Duct Hose" made of EPDM rubber. The 6" size is 7.87/ft . There's also a version with a wear strip which I didn't get. This is probably the fifth year of use I've gotten out of it, and so far no obvious deterioration.
   / Lawn Vac tubing #7
You can also special order it from Tractor Supply Company. No matter where you buy it, it's over priced.
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
