lawn tractor
/ lawn tractor #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
does kioti make a small, 15-20 hp, lawn tractor with a mid pto and belly mower, plus the rear pto for other implements?
heehaw
/ lawn tractor #3
Jon, isn't the LB1914 really the smallest tractor Kioti makes? At 20.5 HP it is the lowest HP rated Kioti tractor, but I guess in weight it is larger. Anyway either of those two would be a good choice. John
/ lawn tractor #4
The LB1914 and the CK20 are both powered by the same engine(3C093). He was wanting a mid PTO though so he would have to go with the CK20, and if you go with the HST its a live PTO.
/ lawn tractor #5
That's right, Jon, I hadn't thought of the MMM and LB1914. Well, I love my CK20HST even without a MMM. I'm still using my old lawn tractor for finish mowing.
/ lawn tractor
thanks for the information, but what do you mean by "live power" pto..does the pto stop when you push in the clutch??
any idea how much $$$ the ck20 goes for??
heehaw
/ lawn tractor #7
I paid under 10,000 for my CK20HST. Buy the attachments with the tractor so you get them cheaper. John
/ lawn tractor #8
The PTO does stop when you push the clutch in, but it being a HST you would never have to do this unless you wanted to engage or disengage the PTO, or to start the tractor. So in a sense it has live power to the PTO during forward and reverse operation. The gear CK20 is usually about 1000 less than the HST, I find this price difference typical in most other brands too, but this may vary from dealer to dealer.
/ lawn tractor #9
I try never to disengage the PTO by using the clutch because I hate the racket that the slip clutch makes! Yes, it's considered a "live" PTO, but through the use of a slip clutch rather than dual acting clutch which would not make the noise. Just reach to the side and push back the PTO lever to disengage. Pushing the clutch or turning off the PTO will only allow a spin down of the blades, it won't stop instantly, so keep that in mind in an emergency. It also won't push your tractor from PTO spin if you do push the clutch, but it is going to make the slip clutch chatter! Hope this helps, John
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
