Lawn tractor won't start, no click, new solenoid and ignition switch
   / Lawn tractor won't start, no click, new solenoid and ignition switch #1
medforded692
Husqvarna yth24v54
I was mowing the lawn yesterday and got off the mower to move something, the PTO was disengaged, and the mower stalled.long story short, I replaced the solenoid and ignition switch and still nothing. shorted the solenoid and it started,so the starter is good. Need help figuring this out
And yes the parking brake was engaged
Not even a click when I turn the key to start.
   / Lawn tractor won't start, no click, new solenoid and ignition switch #4
Seat or PTO safety switch stuck or failed ?
   / Lawn tractor won't start, no click, new solenoid and ignition switch #5
And welcome to TBN
I'm trying to test the brake interlock safety but can't seem to get it out
   / Lawn tractor won't start, no click, new solenoid and ignition switch #7
I would help us help you if you identified your machine. Make model and year.
Richard
It's a Husqvarna yth24v54
   / Lawn tractor won't start, no click, new solenoid and ignition switch #9
The Husqvarna operator manual lists these possibilities:
1. Brake pedal not depressed
2. Attachment clutch is engaged
3. Weak or dead battery
4. Blown fuse
5. Corroded Battery Terminals.
6. Loose or damaged wiring.
7. Faulty ignition Switch
8. Faulty Solenoid or Starter.
9. Faulty operator presence switches.
However, based on your post, we can rule out 1, 7, and 8 for the time being. Maybe even 3 and 5, but I'd want to take a look at them anyway.
This wiring diagram should help you locate areas to probe with a volt meter.
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2020 DRAGON ESP...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
