Lawn tractor won't start, no click, new solenoid and ignition switch
   / Lawn tractor won't start, no click, new solenoid and ignition switch #1
medforded692
Husqvarna yth24v54
I was mowing the lawn yesterday and got off the mower to move something, the PTO was disengaged, and the mower stalled.long story short, I replaced the solenoid and ignition switch and still nothing. shorted the solenoid and it started,so the starter is good. Need help figuring this out
And yes the parking brake was engaged
Not even a click when I turn the key to start.
   / Lawn tractor won't start, no click, new solenoid and ignition switch #4
Seat or PTO safety switch stuck or failed ?
   / Lawn tractor won't start, no click, new solenoid and ignition switch #5
And welcome to TBN
I'm trying to test the brake interlock safety but can't seem to get it out
   / Lawn tractor won't start, no click, new solenoid and ignition switch #7
I would help us help you if you identified your machine. Make model and year.
Richard
It's a Husqvarna yth24v54
   / Lawn tractor won't start, no click, new solenoid and ignition switch #9
The Husqvarna operator manual lists these possibilities:
1. Brake pedal not depressed
2. Attachment clutch is engaged
3. Weak or dead battery
4. Blown fuse
5. Corroded Battery Terminals.
6. Loose or damaged wiring.
7. Faulty ignition Switch
8. Faulty Solenoid or Starter.
9. Faulty operator presence switches.
However, based on your post, we can rule out 1, 7, and 8 for the time being. Maybe even 3 and 5, but I'd want to take a look at them anyway.
This wiring diagram should help you locate areas to probe with a volt meter.
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2012 SANY SRC 840 4x4x4 40 Ton Rough Terrain Crane (A60460)
2012 SANY SRC 840...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
iDrive TDS-2010H...
