Lawn tractor starting problem
/ Lawn tractor starting problem #1
Sam1943
Stockton, MO
Ford 1900
I have an old lawn tractor with a 14 hp Briggs & Stratton electric start engine. When I tried to start it the engine wouldl turn over just fine but it didn't really try to start. I stopped cranking and waited a second and then turned the key and all I got is clicks. It is like instant dead battery. When I stop cranking it is still going great. No gradual die, it is there and then it isn't. I feel like it is the starter but mechanic skills aren't all that great. Any suggestions will be much appreciated.
/ Lawn tractor starting problem #2
Check the ground cable at the frame, or, whatever it is connected to. Make sure it has a good bright connection, and it tight.
/ Lawn tractor starting problem #3
Your initial problem is probably bad or no gas in the carb. See if it has a drain or solenoid on the bottom of the float bowl. Remove that and verify good gas is going to the carb. Sometimes the needle valve will stick closed. If so you can sometimes blow into the fuel line to get it to open but replacement is the fix.
Second it sounds like the battery went dead. Clean all connections and charge the battery.
/ Lawn tractor starting problem #4
What is the voltage measured on the battery posts?
/ Lawn tractor starting problem #5
All good suggestions. But don't forget the starter relay also. Burned contacts on the starter relay will often give intermittent current flow and intermittent starting results. Also don't forget to check your valve clearance on OHV engines. This is easy to do but if the clearance gets to loose the engines wont crank properly often putting a larger than normal current load on the electrical system that will often burn the starter relay contacts. There are a lot of youtube videos on this wonderful Briggs and Stratton phenomenon.
/ Lawn tractor starting problem #6
1. Clean all connections
2. Get volt meter
3. Verify battery voltage is 12.5+
4. If still dont crank, follow through the wiring checking voltage as you go
/ Lawn tractor starting problem #7
Another possibility on that engine is the fuel shut off solenoid failing. Check to make sure the oil level is correct. If it's over filled and smells of gas the solenoid is the likely cause. If it fails to seal off the main jet fuel can fill the cylinder and hydrolock the engine.
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
B&W Gooseneck Ball, Unused (A66408)
B&W Gooseneck...
New Holland 851 Round Baler (A66408)
New Holland 851...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Towable Air Compressor (A64553)
Towable Air...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
