Lawn Tractor for 1/3rd Acre
   / Lawn Tractor for 1/3rd Acre #1
MikeFitz11
Hello everyone,
I'm very inexperienced in the area of lawn tractors, but I'm moving to a house with 1/3rd acre. The yard is flat and open, seems perfect for a lawn tractor. So far I've looked at John Deere LA series, as well as the X300. I've also looked at the Simplicity Regent. I bought a membership to Consumer Reports and they have the JD X304 and X300 rated near the top, unfortunitely they do not rank Simplicity.
I've had several recommendations for each tractor. Supposedly the LA series was designed for yards like mine, but after reading hundreds of poor reviews, I'm really hesitant to go in that direction. It appears the X300 is a safer bet, but I've read many people who insist you need to buy at least an X320 or higher. As for the Simplicity, I dont care about the lawn striping, and I know just as little about their durability.
Bottom line: I just want a tractor that will cut grass for many years with the least amount of problems on a flat 1/3rd acre. What do you think the best option would be for me given the work the tractor will be called upon for? Thanks for any input!
   / Lawn Tractor for 1/3rd Acre #2
Your statement, "many years" is the key. Any Big Box mower will work for your needs, but it is a matter of comfort, reliability and endurance.
Only you can decide if an X300 model, with its higher price is worthy of your consideration. Certainly cannot recommend the base model, say around $1000-$1200 you find outside of Home Depot or TSC. You seem to have more discriminating taste, which is fine. The better mowers justify their $2500-$3800 price by thicker deck metal, better engines, stronger frames, higher quality suspension parts and so forth.
Is there any reason to buy more than an X300 for what I'm looking for?
   / Lawn Tractor for 1/3rd Acre #4
With your interest in having the machine for many years, I think the upgraded tranny in the x320 (or a similar machine of another color (brand)) would be a good idea. Might be slightly overkill for a small lawn, but not a bad idea when long term durability is the objective.
   / Lawn Tractor for 1/3rd Acre #5
Would be a great choice for a 20+ year life mower.
If you buy a Homes Depot junker, expect maybe 5 years out if it, and then throw it away. Cheap price=cheap components.
I've always bought quality Deere mowers, and they have all lasted 15 years and still performed like they were brand new yet. I bought one cheapo mower, and it lasted 3 years, and was then taken to the dump, because the whole front end fell off, and the transaxle exploded.
Thanks for the advice on the better model. Any idea how the X320 or X300 compare with the Simplicity Regent on durability?
Also, are mulching blades the way to go or does it make more sense to side dispense?
   / Lawn Tractor for 1/3rd Acre #7
I will chime in on a Simplicity mower . My uncle gave me his old 2000 Simplicity Broadmoor ( 16hp / 44" deck ) that had been sitting in his wood shed for 2 years unused . I changed the fluids and filters put in a new battery and spark plugs . It is a beast . The floating deck does a nice job , ride is comfortable , has plenty of power and is really well made . The striping roller does work well but in my opinion it is a little gimmicky , my lawn is far from a golf course though .
He gave it to me with 182 hours this spring right know I'am at 210 and there is a lot of life left in her . So far I am really impressed with the quality of this machine .
Have you considered looking at used machine's ?
So is the general consensus that Simplicities are built as well as deeres? What Deere would you compare a Broadmoor to? X300, X320, X500?
Used..not really, I feel like I just dont know enough about them to get something used. That just introduces another variable of wear and tear, seems like it makes it more of a guess...? I'm not sure where to go in order to buy them either, I live in Pittsburgh.
   / Lawn Tractor for 1/3rd Acre #9
1/3 of an acre ain't much grass cutting[does that include house and buildings?],wouldn't spend more than 2-3 grand if that,you got lowes/sears/huskys/cubs,cheaper models that are all about same,than maybe snapper/simplicity,for a little more,but don't know if they are really worth a little more?
Than you got deere,kubota,etc,very expensive,are they worth that much more? I doubt it myself.
Until the suggestion for the JD X320, I had the X300 as the most expensive I wanted to go. I know its a weaker transmission than the X320, but how hard is this transmission going to be working on a flat 1/3rd acre, if I'm only using it to cut grass? The 1/3rd acre includes the house, but the house is just small cape cod. There's no woods, and few trees. The lot is almost entirely flat grass.
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2000 Ford Ranger Pickup Truck, VIN # 1FTYR10V0YTA06580 (A51572)
2000 Ford Ranger...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
