Lawn roller - Modifying to fill with water
   / Lawn roller - Modifying to fill with water #1
JayC
MI's Thumb
I recently acquired an old lawn roller that was home made. It was made out of an old, round gas tank. On top it has a place to put weight. There is no way to add water. I'd rather be able to fill it with water instead of trying to find a bunch of weight to put on top of it. My question is, what do I need to put a hole in it to fill it with water and then plug the hole? Sorry for the stupid question. :eek: Thanks!
   / Lawn roller - Modifying to fill with water #2
Torch a small hole and weld a big nut over it. Use the bolt as the filler/drain plug. Probably want a good sized nut you can run a garden hose thru.
That's a good idea! :thumbsup: I hadn't thought of that. Now I just gotta find someone with a torch and welder. :laughing:
   / Lawn roller - Modifying to fill with water #4
Great idea.
How about welding a pipe coupling with a threaded plug. Might be a better seal.
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
BUSH HOG 7007 LOT IDENTIFIER 37 (A53084)
BUSH HOG 7007 LOT...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
