Lawn roller - Modifying to fill with water
   / Lawn roller - Modifying to fill with water #1
JayC
Veteran Member
MI's Thumb
I recently acquired an old lawn roller that was home made. It was made out of an old, round gas tank. On top it has a place to put weight. There is no way to add water. I'd rather be able to fill it with water instead of trying to find a bunch of weight to put on top of it. My question is, what do I need to put a hole in it to fill it with water and then plug the hole? Sorry for the stupid question. :eek: Thanks!
   / Lawn roller - Modifying to fill with water #2
Torch a small hole and weld a big nut over it. Use the bolt as the filler/drain plug. Probably want a good sized nut you can run a garden hose thru.
That's a good idea! :thumbsup: I hadn't thought of that. Now I just gotta find someone with a torch and welder. :laughing:
   / Lawn roller - Modifying to fill with water #4
Great idea.
How about welding a pipe coupling with a threaded plug. Might be a better seal.
CASE IH 1083 - 8R CORN HEAD (A51247)
CASE IH 1083 - 8R...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2013 John Deere 824K (A53472)
2013 John Deere...
2019 JOHN DEERE 8245R LOT NUMBER 173 (A53084)
2019 JOHN DEERE...
