Grading lawn leveling
/ lawn leveling #1
KSokol
cairnbrook, PA
127 cub cadet; BX 24 kubota
have around lawn that used to be a old fram field (30 yrs old) anyways the lawn is very rough with holes and ruts. very bouncy ride when cutting. what would the best approach be to grading and leveling lawn. please advise
/ lawn leveling #2
Welcome to TBN.
There handful attachment could do the job..harrows,box blade,tiller,scraper blade,etc...
depending how big your lawn might consider rent/hire dozer to level or back drag.
/ lawn leveling #3
I used to landscape yards years ago. We used a box blade to level it and then rakes (by hand) to get the rocks, sticks, clods etc, out of it.
These were subdivision size yards, so it may not work if you have a 5 acre yard.
/ lawn leveling #4
something like a harley rake might be the easiest thing if you have any amount to do.
you could try top dressing with sand to fill in the ruts if you dont want to replant the area
/ lawn leveling #5
I'm guessing that you don't want to completely tear up the lawn to try to get it flat. If so:
Try aerating the heck out of it with a coring aerator when it is fairly wet. Concentrate the aerating on the high spots.
Add a bit more water and then go over the lawn with a heavy lawn roller.
The roller will push the high spots into the holes as the soil is compressed. Repeat the aerating and rolling until it is as you like.
If you rake the cores out of the way, or into low spots, the process will be more effective and efficient.
/ lawn leveling #6
to keep from tearing all the grass out and leveling under it, I have had some good luck with a set of disc harrows, set the gangs to cut straight. so you are just slicing the sod not destroying it. make several passes in both dirctins so that yard is checkerboarded. Then go over it wit a heavy roller. to flatten it all out.
/ lawn leveling #7
I attack the high spots with my loader buddy in reverse, fill in the holes with dirt as needed. Don't want to redo the whole lawn. I am reclaiming some field to mow and am dealing with old furrows and the like. In the end it will be smooth enough to get a little speed on the zero turn.
/ lawn leveling
Actually it is 4 acres and not concerned about the grass -based on every ones comments run over with box blade followed with york rake - and heavey roller. do not think i could talk wifey into dozer, but will try
/ lawn leveling #9
A disc has always amazed me how well they take care of furrows etc. It will take some time to get it perfect that way but I have seen it done it depends on what tools you have available I suppose?
Steve
/ lawn leveling #10
I am having to re do most of our 3.5 A. Not worried about the grass either so I rolled the harrows over in the aggressive position and then put the training wheels on the rake and have had good results.
/ lawn leveling #11
I would use a landplane/grader to do this job. Quick and easy.
/ lawn leveling #12
If the humps aren't too far apart, you can disc to loosen everything then drag the whole thing with a 6'-8' long I-beam to level it off.
2017 Land Rover Discovery Sport SUV (A64557)
2017 Land Rover...
2022 EZ-GO ELITE...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
