Lawn boy 2 cycle
   / Lawn boy 2 cycle #1
dodge man
Super Star Member
West central Illinois
JD 2025R
What happened to Lawn Boy using 2 cycle engines on their mowers? I have a 2 cycle made in 2003, so I don't know when they dropped them. It looks like they use Briggs and Stranton egines now. I always thought Lawn Boy was known for making great 2 cycle engines, what happened?
   / Lawn boy 2 cycle #2
I think it was emissions regulations that killed the 2 stroke lawnboy. Also it was probably cheaper to get a off the shelf motor and bolt it on.
   / Lawn boy 2 cycle #3
IMHO I think the last good lawn boy mower was when the OMC engine was built. I think the last year for this was ~92-94??? When they went to using Tecumseh engines that sunk the brand for Toro and made them just another mower. I am still using a self propelled built in 1978 and it is strong.
   / Lawn boy 2 cycle #4
Yep, when OMC made the 2 cycle Lawnboy, I don't think they could be beat. I bought a used one in 1971 or 1972 and it was still a fine lawnmower when I gave it away in 1989 because we were going to full time RVing. A good friend used his for at least 25 years that I know of. Their website still listed the 2 cycle option 5 or 6 years ago, so I'm not sure when they quit making them. One of our daughters bought a home that included a year old Lawnboy with a Tecumseh engine in 2000 or 2001. It's not been bad, but certainly not what they used to be. And now Toro owns them, so you can buy a red one with the Toro name or a green one with the Lawnboy name.:D
   / Lawn boy 2 cycle #5
I have a Toro two stroke that I've had for about 20 years now. It's got a Suzuki engine on it. Finally replaced the spark plug this past month. It's been a great lawnmower.
Steve
   / Lawn boy 2 cycle #6
Steve- I've got the same mower- unfortunately I had a lot of rocks in the lawn due to new construction, so I eventually put in a short block because the bearings took it on the chin, including the rod bearing (of course, rod/crank is one assembly:mad:).... With the new block in it, she's been back up & running the past 4 yrs. Hope to keep it another 20.
That Suzuki "GTS" has been a good runner, starting up every year on the 4th or 5th pull after sitting all winter. Toro blades are too pricey, however- last one was $18.95! Have you ever found a decent replacement?
I'm told that all mowers have dropped 2-strokes due to emissions; don't figure I can afford to switch to a 4-stroke with an oil pump, so I keep the old 2-stroke going. I have too many slopes to go through splash-lubed 4-stroke engines burning up!:D
   / Lawn boy 2 cycle #8
I found a whole mower for "free" from Pittsburgh Freecycle.org. It's a list where people give stuff away and someone was giving away a Toro with the Suzuki engine on it. And there was nothing wrong with the mower at all. I got it as a spare engine for mine in case it ever fails.
Steve
   / Lawn boy 2 cycle #9
I'm sure the torque of the 4 strokes was a huge advantage, and they couldn't keep running 2 strokes when the competition was running 4 strokes.
Todays people are too stupid and lazy to realize how to run a 2 stroke engine, so thats also a complicating matter. Most have no clue what mixed gas even is, muuchless what needs mixed gas! :eek:
   / Lawn boy 2 cycle #10
Two STROKE engines(all engines are ONE CYCLE but some have 2 strokes to their one cycle and others have 4 strokes to their cycle.....whew) were better cutting on side hills where oil delivery was a problem for 4 stroke engines. I still have a 2-stroke Lawn Boy that is over 20 years old. I think I'll go cut the lawn at the Sierra Club with it ;)
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
