latest roomba just went TU again!
   / latest roomba just went TU again! #21
Soundguy Yeah, I was kidding you. You might check that the four double window 'cliff sensors' are clear.
Right now I'm sitting at my desk keeping the roomba from getting into the rat's nest of wires with my feet.
The manual is pretty poor. It talks about the beep signals and doesn't list them. You have to go to the forum to get that info. I didn't know about the handle or pull out front wheel till you posted about them. My front wheel collected quite a bit of lint.
I'm using the lighthouse for the first time now and it works. But I understand that their claim of four rooms is an exageration. The battery won't last that long.
If you use and charge your roomba twice a day I expect that it will last only three to ten months. And that's not the fault of the design. NiMH batteries will only recharge 200 to 500 times. It's lucky that they don't supply Nicad batteries or it would be even worse. If they used Lion (lithium ion rechargable) it would be much better but the replacement cost these days would be three times as much.
I see they just came out with a model 580 but that just adds a brush kit to the 570 for a hundred dollars more. Still some people like to pay more for something in the belief that it must be better.
Yep the little windows are crystal clear.. however.. i believe i-robot does not invest in the best sensors. our first model, was taken back because it 'went blind'.. the little sensor at the top went bad... I'm guessing they use a simialr design for the bottom sensors..
soundguy
   / latest roomba just went TU again! #23
I am on my fourth or fifth roomba over the years, and never have had a warranty complaint, or problem other than the batteries. The only thing that has ever happened to me is the rubber wheel came apart after hanging up on something sharp once. Right now we have two of them and the secret is to not to try to clean too big of an area with one we do two rooms max and usually only do one with them. We have the ones with the bases etc, but still only manually start them and then let them run in a small to medium sized room. Clean, charge repeat, they work very well for us, we have tile, hardwoods and carpet.
Just had to get another one last week. extended warranty was up... bought another.... maybee sears will pressur ethe company not to build junk?
soundguy
   / latest roomba just went TU again! #25
Soundguy said:
maybe Sears will pressure the company not to build junk?
soundguy
You're kidding right???...:D
   / latest roomba just went TU again! #26
soundguy
Why did you buy another one?
   / latest roomba just went TU again! #27
Are these the machines that ppl make/buy clothes for them??
I remember seeing something on one of the tv news shows about that..
just curious
Brian
Had to.. got hundreds of dollars tied up into that plastic little piece of sh- er junk.. so to get another unit had to renew the extended warranty that went out... It was either that or take the store to small claims court to get all my money back for the originl purchase plus the ext. warranty.... which I seriously considered doing...
soundguy
just curious
Brian
Hmm? don't think I've ever seen any clothes for a roomba.. however.. if it needed a hat.. they should make little garbage can lids for them.. at least it would be truth in advertising...
soundguy
   / latest roomba just went TU again! #30
soundguy
Just to verify I wasnt crazy.. Here is a link I found
http://www.myroombud.com/
but maybe i was dreaming.. LOL
Brian
1002 (A47477)
1002 (A47477)
2013 Ford F-550 Ambulance (A55788)
2013 Ford F-550...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
NEW Woods 6ft Finish Mower (A55218)
NEW Woods 6ft...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
Year: 2016 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A55788)
Year: 2016 Make...
