LATEST ON THE NEW COMPACT TRACTOR
   / LATEST ON THE NEW COMPACT TRACTOR #1
spencer200
Platinum Member
Well folks I just got the sales brochure on the new sub compact and new Class 4 compacts. The sub compacts will come in the following configurations TZ18DA- 18HP-2 Range hydro, 4x4, mid mount mower as standard equipment, TZ24DA- 24HP same equipment as above, there is also a version of the TZ24DA with sensitrak auto fwd. One of the big features I noticed is that the hydro pedals will be seperate for forward and reverse. Cruise control will be optional, 3 point hitch will have a 700lb lift capacity with a 5.6 gpm hydraulic system, diff. lock, open semi flat deck, high back contoured seat. These are going to be available sometime this fall no firm date yet. The info on the class 4 is as follows.
TC48DA 4x4, 12x12 sss trans/ independant pto. The TC55DA is the same with and optional ehss trans. The TC55DA is scheduled to start shipping to dealers in 3 weeks so look for them soon on your dealers lot. The hydraulic pump provides 12.03 gallons plus and extra 5.52 gallons on the steering pump. The 3pt hitch will have a 3469lb lift capacity. The 18la loader will have a 2500lb lift capacity at full height. The TC48DA has a release of sometime later this fall.
   / LATEST ON THE NEW COMPACT TRACTOR #2
Spencer:
Do you have a scanner, can we see a pic from the brochure?
Whiskey
no I dont they came on cd rom and I can not get it to copy into the post because it is a pdf file.
   / LATEST ON THE NEW COMPACT TRACTOR #4
You can do a print screen.. & past into a .bmp file using paintbrush..
   / LATEST ON THE NEW COMPACT TRACTOR #5
Can you attach the PDF to a post, or are only images allowed?
John
   / LATEST ON THE NEW COMPACT TRACTOR #6
I think only image files can be attached. You could always save the pdf file to a webpage elsewhere and put a link to it on here.
Well I must have my stupid hat on today I also tried to paste a bmp file into my post and that did not work either.
   / LATEST ON THE NEW COMPACT TRACTOR #9
TZ18 and 24 - Pic 1 of 2
Attached are the pics of the new sub-compacts.
   / LATEST ON THE NEW COMPACT TRACTOR #10
Re: TZ18 and 24 - Pic 2 of 2
Second page
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2022 Freighliner M2 4 Car Rollback (A53117)
2022 Freighliner...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
