Lastec 3372 Mower Will Not Start
   / Lastec 3372 Mower Will Not Start #1
qbc3
morrow, ohio
Lastec 3372/B1700/B2150
I have a Lastec 3372 mower with a 33 hp turbo charged Kubota D1105-T-ES engine. I haven't used it since November. It will crank, but will not fire. When I crank the engine it gets fuel at least to the fuel pump bleeder valve, but not to the injectors at the engine. It may be obvious, but does this mean that the problem is definitely a faulty fuel pump.
What's my next diagnostic step??????????
   / Lastec 3372 Mower Will Not Start #2
Crack one of the injectors loose and crank it to see if the fuel is just not getting through or if there is no supply.
Ed,
I loosened the connection point of each of the 3 fuel lines to the injectors, separated the connection points and get no fuel when I crank the engine. So, it's not getting fuel to the top of the injectors.
   / Lastec 3372 Mower Will Not Start #4
I would try bleading the pump realy well before I gave up and had the pump rebuilt.
Does anyone know if possibly a faulty fuel solenoid could be the culprit? And ... if so, how could I check the solenoid out to determine whether it's functioning properly or not?
Thanks
Here's an update. Took the injector stop solenoid off and it did not cycle when I cranked the engine. The prong stays in the extended position, but will depress with finger pressure. (The rack itself was not stuck and operated smoothly when depressed with my finger.) I left the solenoid disconnected and then took off the injector lines coming off the top of the injector pump. Cranked the engine and got the spirts of fuel indicating the pump was working. Blew out the injector lines and then reattached them back to the pump and cranked the engine and watched the fuel coming out of the disconnected injector lines at the individual injectors. Reconnected the stop solenoid; cranked the engine and no fuel came from the disconnected injector lines.
Does this means the stop solenoid is bad or maybe a bad relay to the stop solenoid?
Well, here is the latest status report:
I decided to try to start the engine without the stop solenoid in place. I reasoned that by removing the solenoid, I would be assuring that the solenoid plunger/fuel rack shutoff relationship would be taken out of the equation. Guess what; the engine kicked right over and ran until I manually put the fuel rack into the shutoff position.
So......, is there any reason I should not assume that the stop solenoid is bad and replacement is in order?
Stop solenoid was bad. Replaced it and mower runs great.
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
John Deere A Tractor (A50514)
John Deere A...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
