Lasers at aircraft - How to catch?
   / Lasers at aircraft - How to catch?
I'm sensing a "go easy on him" energy forming to. Aww... poor little prankster accidentally over did it.
At the same time, why cost the taxpayers millions wen he's sure to be harmless from here on out. Fine him $5,000,000 and give him a couple years. /forums/images/graemlins/cool.gif
   / Lasers at aircraft - How to catch? #22
I wanted to know why they had to use "the patriot act" to charge him when there is already a law against this type of activity.
   / Lasers at aircraft - How to catch? #23
</font><font color="blue" class="small">( If you can consistently track a cockpit pit window on a moving aircraft, then you need to start training for the Olympics and please let the USAF know how to do it, since they appear to be having problems in this area.)</font>
Your statement breaks down on the word "consistently." To be a valid military weapons system, it needs to be consistent. To be a harassing and potentially fatal activity, it doesn't.
The militaries of the world have several lazer dazzler systems, most of which are tracked with simple optical sights. We have taken military casualties from their use, and have used them successfully as far back as the Falklands War, where I believe the Brits caused several crashes. I believe that laser-protective goggles are in wide use. They're certainly available for issue. I suspect the piloting community is buying them up, now. I would be.
It's a lot easier issue to injure an eyeball in a low flying, slow moving aircraft, than to burn a hole in a satelite. It's easier, if the beam is a little unsteady, or has a wiggler. That way, it paints a fairly broad area compared to the pinpoint beam.
An industrial cutting laser certainly has enough power to cause this kind of injury at great distances. Because of the aiming issue, I suspect a homemade system, and probably a military system as well, would have only a limited effective range.
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
Pickup Truck (A59230)
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A59575)
2016 FORD F-550...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
