Tires Larger tires on a 2210
   / Larger tires on a 2210 #1
Bulldog160
WNY
JD 2210
Curious as to if anyone has put larger than stock/factory tires on a 2210?
Since I'm going to be upgrading to ag/bar tires I thought I look into going a little larger if possible.
   / Larger tires on a 2210 #2
I'm no expert on front wheel assisted machines, but I would make sure larger tires would not damage the drive train on that unit.
   / Larger tires on a 2210 #3
I agree. I wanted to buy the ag tires as an alternate to the turf tires when working in the ooze of spring,but was advised that I need new rims etc.
I believe that ag, turf, R4 tires in the same size (26x12.00-12) use the same rims. Let me know if I'm wrong.
   / Larger tires on a 2210 #5
I am pretty sure the AG tires are mounted on narrower rims than the Turf or R4's do.
Also remember that changing tire sizes directly affects the entire drive-train gear ratio's. You will either loose top end speed or low end torque. Also severe damage can result using 4WD if the proper size ratio's are not maintained from front to rear.
Contacted Kane Morrow of Morrow Tire Supply regarding Turf vs. Ag rim size:
If you have 26X12.00-12 turfs yes they use the same rim.
Thanks,
Kane Morrow
Morrow Tire Supply
943 N Miami Ave
Marshall, MO 65340
www.morrowtire.com
   / Larger tires on a 2210 #7
I wanted to put larger tires on my 2210 and was told by dealer it would void the warranty on the front 4 wheel-drive.
   / Larger tires on a 2210 #8
sizing is critical
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
Generac Generator (A50774)
Generac Generator...
Truck Tool Box (A50774)
Truck Tool Box...
NPK H2XA Skidloader Breaker (A50774)
NPK H2XA...
