Larger Battery for UTV??
   / Larger Battery for UTV?? #1
Boeing
Platinum Member
Botetourt, Va
kubota L3010
I have a Kubota DIESEL UTV. No problems but just added a Winch. I know that a winch draws alot of powerr. The battery box (under and behind driver) seems large and I was wondering....hmmm...could I install a larger battery? Suggestions? Thanks
   / Larger Battery for UTV?? #2
No reason why you couldn't, as long as it fits. 12 volts is 12 volts.
I have a Can-am Defender; lots of folks on the Can-am forums are doing just that...only they need the extra power to run 2000 watt stereo systems that can be heard over the roar of the engine.
   / Larger Battery for UTV?? #4
My rule of thumb is.. I always install a replacement battery as large as the battery tray will allow. CCA is CCA, the more the better. Just installed a HF winch on our Kubota gs850 side by side. I used welding cable for the leads with soldered on and crimped TWECO lugs on both ends.
   / Larger Battery for UTV?? #5
I went up about 50% bigger CC amps on my Pioneer.
I moved it from the passenger side to the driver's side.
It fit inside a plastic ammo box.
I cobbled some brackets and re-routed the wires.
Some have purchased two same sized batteries and connected them.
Others have added a battery independent of the engine battery for accessories.
Lots of options.
Thanks, guys....all great answers. One last thought, since the buggy bounces around alot should I spend the extra $$ to get an AGM battery? I plan on putting an AGM in my tractor too....cause it has NO suspension. (Thank heavens for my seat springy thingy. :oops:
   / Larger Battery for UTV?? #8
Yes, you can get a larger 12v battery. The other option is a dual battery setup. On my trail machine (Talon), I run duels due to the winch, communication radio, and extra lights. We wire in a battery separator, so the accessories run off the "2nd" battery, and the machine uses the primary battery for starting and such. This way they both charge when the UTV is running but if you kill the battery winching out the main battery will still be fully charged and ready to start the UTV.
   / Larger Battery for UTV?? #9
Here is an example of the isolator/separator
You can build a kit off amazon a little cheaper but this will give you an example.
   / Larger Battery for UTV?? #10
We like larger batteries than stock just like you but just wanted to remind everyone that UTV and ATV have stators with limited outputs. That is we still need to keep whatever battery you have, charged to full. The Polaris we used for the past 5 years couldn't keep lights, hand warmers and battery up, all at the same time. Larger batteries still need to be kept up.
2017 JOHN DEERE 210G LC EXCAVATOR (A45046)
2017 JOHN DEERE...
2013 BMW X5 AWD SUV (A42744)
2013 BMW X5 AWD...
2017 Dodge Charger Sedan (A42744)
2017 Dodge Charger...
2019 WYLIE HYDRO EXCAVATOR TRAILER (A45046)
2019 WYLIE HYDRO...
2017 GMC Savana (A44501)
2017 GMC Savana...
INSPECTION (A44391)
INSPECTION (A44391)
