large stump - split the top and pull the pieces?
   / large stump - split the top and pull the pieces? #31
Easiest way?
Flush cut the thing.
Throw an old centerless tractor rim on top.
Dump 2 bags of charcoal inside the rim, topped with a bunch of small splits of wood, and brush.
gallon of diesel and then torch it.
Keep adding small chunks of wood, and keep it burning for a day or two.
Generally, you will have it burned sub flush the first time, but might have to go at it a second time.
Good luck to ya. Big stumps can be a pain.
Start your brush pile on the stump. Burn the brush pile a few times and part of the stump will go with it.
   / large stump - split the top and pull the pieces? #32
Neither of my Kubota's are small (M9's) so when I cut a tree, I get up on a ladder and leave about 8 feet of tree sticking up, choke a chain up at the top, hook one of the M's on the chain to the drawbar and pop it put like a cork. Pulled some big ones in the past, 20" around. The come right out, then I backfill the hole, roast the stump in the burn pile and call it good.
   / large stump - split the top and pull the pieces? #33
I have two ailanthus tree stumps that are 30" diameter.
One I had cut down by a tree company, because it was close to the garage, and the other one split low and went over in a storm.
Both trees have been down, and cleaned up for about 5 years, but I am tired of looking at both 3'-4' tall stumps up close to the garage/house.
Ailanthus trees are basically a fast growing weed, and they grow very large, while also heavily populating the surrounding area with their nuisance offspring.
I have no idea about their root structure, but I am thinking that this is the year those stumps should go.
I see very little rot showing after 5 years, yet these are a soft wood tree.
When I get back up North for the Summer, it will be a good test for the capability of my Kubota L48 TLB.
Of course, it would be an easy job if I borrowed my neighbor's new CAT 306 Mini-Ex (he says, come, just drive it over whenever you need it), but I simply don't "borrow" $90K machines.
He is a good kid, and I want to KEEP him as a friend!
Just have him bring it over and have him demonstrate how well it works on your stump and buy him a case of his favorite beverage. Lol, Jon
   / large stump - split the top and pull the pieces? #34
That is good advice, but I am a stubborn old coot, so am thinkin my L48TLB with 11' hoe will do the job, albeit a bit slower.
   / large stump - split the top and pull the pieces? #35
This forum has discussed stump removal strategies from hand tools to thermonuclear explosives. I'd like to address the original, 8-year old question. The poster wanted to split (or saw) a 30" elm stump 6' tall and pull it out in vertical pieces.
Although the trunk may be relatively straight, and if one is lucky, grain may be straight, the "grain" in a stump is generally contorted and gnarly. I think it likely. that even with a 6'+ lever arm, the trunk portions will break at or near ground level, leaving the roots. I do not have experience with elm. When I was a kid the elms were dying of Dutch Elm disease and being removed. I do recall asking my grandfather why he didn't take some for firewood, and I was told that it was difficult to split, "It will spit the wedges back at you" and that it was poor firewood "Even the flames are cold".
2004 MACK CH613 WATER TRUCK (INOPERABLE) (A58214)
2004 MACK CH613...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
UNUSED AGT INDUSTRIAL SDA-140T LOADER (A58375)
UNUSED AGT...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
15' 18" Corrugated Pipe (A57149)
15' 18" Corrugated...
2012 MACK PINNACLE (INOPERABLE) (A58214)
2012 MACK PINNACLE...
