large stump - split the top and pull the pieces?
   / large stump - split the top and pull the pieces? #11
Easiest way?
Flush cut the thing.
Throw an old centerless tractor rim on top.
Dump 2 bags of charcoal inside the rim, topped with a bunch of small splits of wood, and brush.
gallon of diesel and then torch it.
Keep adding small chunks of wood, and keep it burning for a day or two.
Generally, you will have it burned sub flush the first time, but might have to go at it a second time.
Good luck to ya. Big stumps can be a pain.
   / large stump - split the top and pull the pieces? #14
Shovel, grub hoe and an axe.:D
not at "our age" and not in your slate and granite either. or do you still look like Paul Bunyan?
You're right, as kids that's all we had. And an old McCulloch chain saw. And a big heavy bar
with a cutting edge. No wonder my back is ruined 50 years later...
   / large stump - split the top and pull the pieces? #15
Thanks for the pictures
   / large stump - split the top and pull the pieces? #16
I just had a similar sized stump to deal with (36" maple). I even have a BH, but it's not worth digging out one that big unless you're putting a building on top of it or something. I just rented a stump grinder and ground it down 6 - 12" everywhere and then backfilled and called it a day. If you can grind down most of the center then the roots don't have that much volume, so as it decays you shouldn't end up with much settling. A chainsaw probably isn't going to help much, but if you go that way you can get a carbide chain, which may help it stay sharp and they make chains specifically for cutting along the grain.
   / large stump - split the top and pull the pieces? #17
As a kid on the farm, we used dynamite to remove stumps. I don't know if you can still get dynamite.
I would vote for burning the stump.
Obed
   / large stump - split the top and pull the pieces? #18
Obed
Black powder should also work.:D
   / large stump - split the top and pull the pieces? #19
you could sell tickets for that...
some nice slo-mo video on that would be fun!
really have to be on a big or remote property to do that anymore.
Today there must be 115 ordinances in our area about making more noise than
popping a balloon... ;)
   / large stump - split the top and pull the pieces? #20
Delay timer and be over in the next county when things happen.:D
Brew up some shaped charges and cut it up.:D
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
UNUSED AGT INDUSTRIAL SSHH680 HYD HAMMER (A58376)
UNUSED AGT...
John Deere LA135 (A57149)
John Deere LA135...
2008 Ford F450 Lariat Pick Up (A55272)
2008 Ford F450...
