Large Red Oak Tree
   / Large Red Oak Tree #1
jrdepew
Johns Island, SC
Ford 1920, JD LT180
All,
I have a large red oak in the front yard, about 30" diameter at chest height off the ground. The main trunk is a good 25' long, and straight.
Long story short, the tree is dying due to pine beetles (according to one of the tree companies).
I think what happened is that about 25% of the roots were cut to install a driveway, and then fill dirt was brought in too high around the trunk of the tree when the lot was built up. This was when the house was being built around 3 years ago, all weakening the tree. There is now some sort of insect living in the bottom of the trunk (they make sawdust piles all over the trunk), and bark is peeling off many of the larger branches. It has dropped one branch on our house and one on our cars.
So, unfortunately, it is time for the tree to go. It is one of the reasons we bought the house...these mature trees.
The quotes to get it removed have been around 3k for removal, including stump grinding. One company will do it for 2k, but doesn't do stump grinding.
I am wondering how much good wood will be left in this tree because of the beetles? It seems crazy to take a red oak tree this big and turn it all into firewood. I was considering having a company take the whole top off, and the drop the main trunk in 2 sections. Then I could get a mobile sawmill service to turn it into usable lumber. I have never done anything like this before, but if there is a bunch of good lumber to keep/sell, maybe it will be worth it?
Anyone have any opinions on this or been through something similar?
Thanks,
Joe
   / Large Red Oak Tree #2
My impression is that loggers/mills avoid dealing with trees around home sites -- there's always a chance that they will run into embedded metal and it isn't worthwhile to move their equipment for a single or limited number of logs.
Steve
   / Large Red Oak Tree #3
Bummer. Human's lifespans are too short to replace such a tree.....
Maybe ask around in the community if someone does woodwork such as furniture building, etc?? They might be able to guide you in how to process the log. Maybe the mobile sawmill guy could suggest someone?
   / Large Red Oak Tree #4
It really is a bummer. It sits right in front of the house and is a beautiful tree.
I will continue to ask around.
I do dabble in woodworking and am always building something, so having the lumber would be great. I have an old 12" parks planer with a 3hp motor that would plane it down smooth as glass after a long drying session too...
It does seem like a lot of work to move a mobile mill for one tree though.
Even if someone had a rig that could haul the trunk home and process at their place...if they could move it they can have it all. It would save me money because hauling off the tree is a large part of the cost, and someone would potentially get some nice lumber. I am not sure that is a fair trade with all the effort involved though.
-Joe
   / Large Red Oak Tree #6
IMO there is no telling what you might find inside the tree...As soon as it's cut you will have a better idea about the lumber...The tree could be hollow at the very center and also be full of water...you never know...I've seen even healthy looking trees (no sign of insects etc...) that were not worth milling because they were rotting from the inside...
If the cut/stump looks solid you won't know about the insect damage until you start slabbing it off...could go either way...
When you're inquiring about a sawyer be sure to ask about quarter sawing as it is a preferred method for the grain of red oaks...
Good Luck...
   / Large Red Oak Tree #7
I would seek out a certified arborist first - the tree may be able to recover. Calving limbs is not at all uncommon on oaks. We have a couple hundred in 5 varieties on my little piece of ground, and typically calve a couple large limbs a year. The last one was about half a cord of firewood, and had a few lbs of acorn hulls stored in it by some enterprising squirrel. The main trunk and remaining branches appear sound.
   / Large Red Oak Tree #8
Good Luck...
Yep no way to know. Oaks (and others) can live with a lot of rot on the inside.
I’d caution a full removal until you try killing the funk growing in the tree. Tree “experts” are typically tree trimmers/removers. Not that they are bad or unethical but it’s human nature to look at the world through your own lens- carpenters grab a hammer, engineers grab a slide rule etc.
We were told our red oak needed to be removed as well. Same situation with new sidewalks and new landscape under the canopy. We also had a big limb hit the house. We were also finally told it was over pruned (tree was trimmed when we had the limb hit the house). We finally found someone who suggested we shut off all water under the canopy (lawns, bushes etc) and treat with “X” chemical. Low and behold the stuff growing out of the bark went away and the tree is doing good to this day!
   / Large Red Oak Tree #9
If that many roots were cut PLUS dirt piled up around the trunk, sorry to say "it's gone"--Around here the dirt piled up on the trunk invites carpenter ants and they will kill the trees in a couple years.
Check around, maybe an ad on cl or similar sites and see if someone is interested.
Wish you were close to me, as I would cut it for you! thanks; sonny580
I壇 caution a full removal until you try killing the funk growing in the tree. Tree 兎xperts are typically tree trimmers/removers. Not that they are bad or unethical but it痴 human nature to look at the world through your own lens- carpenters grab a hammer, engineers grab a slide rule etc.
We were told our red oak needed to be removed as well. Same situation with new sidewalks and new landscape under the canopy. We also had a big limb hit the house. We were also finally told it was over pruned (tree was trimmed when we had the limb hit the house). We finally found someone who suggested we shut off all water under the canopy (lawns, bushes etc) and treat with 店 chemical. Low and behold the stuff growing out of the bark went away and the tree is doing good to this day!
Interesting...I will get ahold of someone to look at it that doesn't stand to make their living taking them down.
I did find a local guy with a portable bandsaw mill that travels. He charges a 400 dollar minimum and says if I have 2x 12' trtunks he expects it will take about that 400 dollar minimum to slice them up. If he is close with his estimate, and the wood looks good, that sounds like a good deal to me. I have space to stack and sticker the wood and let it dry...use some here for some projects and maybe sell a slab or two to help with the cost...we will see.
It would be awesome if the tree could stay though...that would be the best outcome.
-Joe
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2019 Ford F-150...
