Laptop Died... Fix? or Replace?
/ Laptop Died... Fix? or Replace? #21
Don't know if it helps but my Toshiba was around a year old when the hard drive started crashing.
While I haggled with Toshiba and Seagate over the warranty I managed to download Ubuntu to a USB flash drive and boot the laptop from it and it didn't even need a hard drive in it.
https://help.ubuntu.com/community/Installation/FromUSBStick
The above is a link to it. I don't know much about it just enough to stubble around between what I have learned from a guy at work and on my own.
But I have managed to use this to remove 3 viruses that had Windows all fouled up and one of these the in laws had a anti virus they were paying for and it located the virus but couldn't remove it..........
Don't know if this helps but it might help make sure it's not just the hard drive.
/ Laptop Died... Fix? or Replace? #22
I think I would try the <$100 fix first, but not spend much more. We have a Toshiba Satellite that had a hard disc die. I ordered a new hard disc online and installed it and Windows XP. Everything was fine for about two weeks and the laptop started crashing again. I was ready to buy another one when my wife talked to a friend who teaches technology at a well-known high school in the Dallas-Ft Worth area. He took the laptop and returned it a week later saying he had fixed it with spare parts he had laying around. I asked him what spare parts and he said a hard disc. What? :confused2: It turns out that the hard disc I bought (a duplicate of the original) died in two weeks. At what I paid for it, it wasn't even worth returning, so I just chalked it up to experience. The laptop has worked fine for over 1-1/2 years since.
/ Laptop Died... Fix? or Replace? #23
$90 to fix the computer is probably worth it just to get data off and to have a spare computer available. I am a little suspicious of the guaranty though as $90 around here will get you a diagnosis on computer repair but not the actual fix.
My own strategy is to replace rather than update computers. I buy solid well configured machines (not game machines) about once every three or four years and don't touch them. Spent way too much time in the early days trying to upgrade computers before figuring out it just wasn't worth the hassle. Now I only buy relatively mature technology and purchase middle of the road computers from Dell, Gateway, Lenovo, HP etc. Never ever upgrade the operating system as that is just paying to have a nightmare experience. With Apple devices I never buy the first generation but find second or every other generation to be reliable and a worthy upgrade. I have an iphone but am waiting for the second generation ipad to see if that is worthwhile.
/ Laptop Died... Fix? or Replace? #26
Which model dell is it?
$90 to fix the computer is probably worth it just to get data off and to have a spare computer available...
Getting the data is not a problem. I've already checked the hard drive, and it works fine in my desktop. I figure I can probably get about $100 for the parts from this laptop on e-bay. Therefore, I'm figuring a $200 committment to this laptop to fix it. Still not a bad price for a computer.
Iplayfarmer, before doing anything else, see if it will boot up with the battery removed and just the AC adapter plugged in. Just a thought.
I hadn't tried that. What's your line of thinking there? If it boots with the AC adapter only does that mean I've just been fighting a bad battery?
/ Laptop Died... Fix? or Replace? #29
Yes that is possible, If it is dead and won't do anything you won't be able to access the dell diags...
It sounds like you have removed the Key Board, Yes? If so some of the dells have a separate "ignition switch" that mount to the MOBO near the LCD end of the MOBO they can go bad, or it may just be needing reseated. On other dell models they have a module closer to the mouse pad that if they come loose the laptop will appear dead until they are reseated. Try to remove things one at a time like memory, dvd drive, etc. to see if anything is causing your issue, pcmia cards...If all fails it more than likely a bad MOBO
Oh and make sure your fan/s are free to move and blow them out if possible, Thats about all I can think of, Good Luck
/ Laptop Died... Fix? or Replace? #30
Also search for the problem you are having, with error numbers if you have found some, and the system model number. The wifey's last laptop was a dog. Some people at work had the same model number at work and they were junk. We fixed it once or twice to get it working. It has been alive for a year or so but we now use it as a kids desktop. There were numerous problems with that system as well as other brands due to common parts.
You might have a system that has a set of known problems and fixes. Though sometimes the fixes are not worth the cost.
We bought a new lap top for her after the second fix. I actually paid for an extended warranty on the system which was good since the hard drive just puked out on the new system. :mad: In all of my years using computers I can only think of a few hard drives that have died. And when they have they have been at least five years old....
At least I bought a warranty! :thumbsup::D I think this was the first warranty I have ever bought. :laughing:
Later,
Dan
/ Laptop Died... Fix? or Replace? #31
Just making sure my post above made sense..............You can download Ubuntu or some other version of Linux and save it onto a USB flash drive and plug that into the laptop and when you turn it on change to boot sequence to make it boot 1st from the USB ports........
This should allow you to use the computer with the hard drive completely removed from the laptop. Then you can be sure your hard drive is where the problem is.
But I may be missing something ...........you talked about error lights......so you may already have narrowed it down to some other part of the computer.
I just know that this Toshiba had the hard drive go bad within a year's time and I ended calling the hard drive manufacturer and getting them to honor the warranty. Because Toshiba wanted me to send in my whole laptop and wait how ever many weeks for it to get shipped there and back..............guess that's what most places do from what I have been told. Seagate, the hard drive manufacturer let me prepay for the replacement hard drive then they shipped a new one and once I got it installed I could erase the old one and ship it back to them for a full refund............
By the way the Linux operating systems are free and I have played around with Knoppix, Ubuntu, and a couple others and sometimes I wonder why computers are being sold with windows already on them because these operating systems seem pretty stable to me and just as easy to use as Windows..........too bad consumers are offered the opportunity to purchase a computer without have microsoft forced upon them............
/ Laptop Died... Fix? or Replace? #32
If you order by phone and get a real human body on the line, you can sometimes buy a unit without an operating system.
My work with dead computers has always found that the cause was software problems (eMachines excluded). Now laptops seem to have a short lifespan because they get bounced around too much.
Please define "new laptop". I have a Toshiba 15.4 screen M35X that is over 6 years old as I type this, it has never given me a moments problem and STILL HAS THE ORIGINAL, OEM BATTERY. It gets moved around a lot, but ONLY after it is shut down...it amazes me how many laptop owners pick their machines up and move them around while the hard drive light is blinking...this one cost me $1200 new with an additional 1.5 GB of memory added for another $100 3 years ago. Two years ago I was able to purchase a second 15.6 screen Toshiba with Vista, $400 delivered from Newegg, no tax, with 2 GB and a 160 GB HD. It amazes me you can buy a decent laptop these days for $400-$500. Unless you have a lot of sentimental attachment to your older computers, spend the bucks and buy a new one, the OS upgrade alone is often worth a quarter of the price. As much as I am attached to my older Toshiba, if it needs repairs over $100, I will not bother as I have my moneys worth out of it after 6 years.
/ Laptop Died... Fix? or Replace? #33
For what its worth I have had 2 repaired by one of the EBAY vendors and both are still working over a year for one and about 8 months on the other. I don't think it was the same person, mine was out of Florida and kept me well informed on what he was testing and repairing. $95.00 well spent.
Rich
/ Laptop Died... Fix? or Replace? #35
I have had good luck with fixing Dell latitude laptops myself. Disassembly and assembly instructions are available online, as are most parts. I have two laptops that I have replaced just about every part, including keyboard, motherboard, processor, RAM, modem, palmrest (with touchpad), hard drive, lcd display. I have bought parts on ebay and from other dealers, and have won cheap parts laptops on ebay. I've motherboards for Dell for as little as $20 and as much as $150 for a newer laptop.
These are good serviceable laptops that are a few years old but still fast enough and useful.
Kind of fun too.
A serviceable laptop should easily be worth $91 to fix.
/ Laptop Died... Fix? or Replace? #36
Its just me but I can't imagine getting a giant iphone when I can get a fully functional Windows 7 Dell Inspiron laptop with Intel processor, 2GB of RAM, 250GM HD and 15.3 inch display, wireless, USB, DVD burner, etc for less money (just paid $399 at Best Buy a month ago). This thing is working great.
Rich
That's very valuable information. Thanks for sharing.
In response to others, I've confirmed that the problem is NOT the hard drive. I've tried all of the jiggle, wiggle, clean, and reseat that I can think of. My conclusion is that there are parts that need to be replaced.
westcliffe01 - I'm not sure I can bring myself to buy a laptop from Toys R Us. ;)
/ Laptop Died... Fix? or Replace? #38
Can the laptop fit in your pocket? :laughing::laughing::laughing:
We finally got smart phones last August. Not an iPhone. Apple products are over priced and I am not paying a premium for a logo. Though the iPhone has a huge amount of after market gadgets that makes things interesting. Our smart phones were on Amazon and seems like one other retailer for $150-200. Found it on NewEgg for $50.
Having a PC in your pocket is very nice. :D It even as a TBN app. :thumbsup: Very nice to have one integrated device that reads email, browses the Internet, is a book reader, plays music, runs a variety of apps, is a GPS, oh yeah, its a phone too. :thumbsup::laughing::laughing::laughing::laughing::laughing:
And it fits in a pocket. :thumbsup:
Later,
dan
/ Laptop Died... Fix? or Replace? #39
I'm not an Apple fan boy but I must acknowledge that since I did finally break down and get an iPhone last year it really has changed the way I use computers. I only pull out the laptop if I absolutely need the keyboard for a long message or need something that cannot be done on the iphone. I have a notebook and a standard laptop neither of which is used nearly as much now as in the past. The iphone is just too quick and convenient. There are fewer and fewer things that it cannot do so I just go to it first.
/ Laptop Died... Fix? or Replace? #40
Concerning the iPad; no "flash" is a deal breaker at any price, along with no usb/firewire or dvd :confused:.
There are a growing number of companies now producing "pads" for a 1/4 of the price. Vizio is getting into the market as well with a pad and a smart-phone.
KUBOTA L4610D TRACTOR (A64280)
KUBOTA L4610D...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
10-16.5 Skid Steer Wheels and Tires (A61572)
10-16.5 Skid Steer...
3147 (A63117)
3147 (A63117)
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
