Lane Shark or TB-One in Canada
   / Lane Shark or TB-One in Canada #1
Hilbilly
Barriere, BC
Kubota Grand L6060HSTCC
Anyone know if these (or something similar) are available from a Canadian dealer. From what I can tell almost all of the dealers are in the eastern part of the US and none in Canada.
   / Lane Shark or TB-One in Canada #2
Unfortunately... I'm not very computer literate, but the searching I did was not showing anything available in Canada.
Not even used, machinery finder kind of sights, you name it. Nothing showed up Canadian made either.
There were some used units on US, used machinery sites. Not sure if they were tractor or skid steer units.
I think that will be an issue to get a mower that is compatible with the gallons per minute available your tractor, skid steer has available for an attachment like this.
Good luck.
I'm considering making one if I can find a cheap used 4' rotary cutter.
I already have a pto mounted hydraulic power pack that I built last year and a hydraulic motor that I used to convert my rear mount snow blower to a front mount hydraulic blower. The power pack and motor are rated up to 20 gpm but I run them around 16 to 18.
   / Lane Shark or TB-One in Canada #4
From the L-6060 it would run from the tractor system if you would elect to use it that way. The price and flexibility of a factory unit is pretty reasonable knowing they work as good as they do! They are built for tractors and not skid steers for the visibility and safety.
Do you have a Lane Shark and if so how long have you had it and how to do you like it? Any issues?
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
