Landscaping tasks, looking at a BX24, will it be enough? Pictures included!
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #241
Taiser,
I think you'll be pleased with the choice. Here's a couple more pics of what a little larger tractor makes possible.
Building Floor for shed
10' x 16' shed floor - Treated 2x6/16" OC - 3/4" plywood floor. This chunk of lumber was heavy and was able to lift it with ease. I used the forks to turn it upside down. Attached three 16' - 4x4 posts with lag bolts to bottom for runners, then used the forks to flip it back right side up and begin on the walls.
Lifting Floor after attaching posts
http://i138.photobucket.com/albums/q263/jk96/Shed-Floor1.jpg
Flipping back over
http://i138.photobucket.com/albums/q263/jk96/Shed-Floor2.jpg
Next time I'll wait to nail down the plywood. The plywood made flipping the floor back over a little tricky.
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #243
Timber,
I post some pics of the place late tonight. I took some today but just have to get into photoshop to resize them.
jk
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #244
cool I love the door too into the ceiling that trick
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #245
Timber said:
Did I mention that I love that shop
That is for sure. I would pay to live in that shop.
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #247
Volfandt said:
The BX23 WAS the best choice for me.
I had a larger tractor and a smaller L&G tractor that I was using to maintain the property so I knew what I was looking for when I decided to consolidate both into one machine with an FEL at a minimum.
I went back & forth between the BX2230 and the B7510 as well as testing out the B7610 & B2410. Price wasn't the primary determiner (is that a word?) just one of many.
Since finish mowing was priority #1 I used that as the main focus but I also wanted a machine that would do more than mow and work 3PH implements. I also needed to carry material around and be able to dig and keep my fence rows cleaned out.
The BX23 fits it to a T.
I don't doubt that it would work out with more acreage. That said, if the more acreage was open field then yes it'll cut 8 acres as well as any other sized machine slinging a 60" cut mower. I would argue that since it has a fully suspended deck that the MMM would require alot less maintenance as well as outlast a ground contact mower.
If the extended acreage was woods that I intended to thin or work in then I would have went with a B series that would have gave me more ground clearance.
Thing is, the BX is Kubota's best mowing tractor and they've increased it's I starte out usefulness by equipping it with an FEL & BH that'll work for the vast majority of suburban /estate landowners. Many of whom push it's envelope which not surprisingly it handles very well :D
I started out intending to buy The B2410.
Didn't even know there was such a thing as a BX23 until I went to the dealer to price the 2410.
After that it was a 2 0r 3 month battle back and forth between the 2 before I decided on the Bx23.
My only regret ~ I couldn't have both of them!
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #248
jk96 said:
Taiser,
Flipping back over
JK,
Don't take that outside on a windy day or you WILL be flying :eek:
TomK
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #249
   / Landscaping tasks, looking at a BX24, will it be enough? Pictures included! #250
BX 24 CANADIAN RETAIL
24500 CANADIAN DOLLARS
BX24 US RETAIL
15500 USD
1.15 EXCHANGE RATE US TO CAD
17825 CANADIAN DOLLARS
so we save 6675 canadian dollars to buy the bx 24 into the us market if you are from Canada.
Some people tell that if you are Canadian and you buy into the us market you will loose the warranty. My point is that even if you loose the warranty you save a lot? Second why there is such a difference between the canadian retail pricing and the us retail pricing?
By the way Taiser are you still looking to by your bx into the us market?
sorry for the previous post hope this one will clarify
Alain
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2000 GMC C6500 20ft Rollback Truck (A55788)
2000 GMC C6500...
Peterbilt (A51692)
Peterbilt (A51692)
