landscaped islands/berms...
   / landscaped islands/berms... #1
Beavis
Kansas
JD 4720
I'm trying to get some ideas for landscaping. I'd like to build some slightly raised areas and display an antique plow, dump rake, or sicklebar mower. I've attached a photo for a starting point; but it is not elevated.
Here are a couple photos of what I've put together....Will update later when I've done some planting. I plan on putting an antique piece of farm equipment on the top and would like to plant a few clumps of pampus grass infront of/around the power box to conceal it.
   / landscaped islands/berms... #3
Looks good, Beavis.
My only thought is "why even use the brick/stone"......? Why not just pile the dirt, level it off, and pull your old piece up on it?
   / landscaped islands/berms... #4
I'm no expert, but I don't think that tractor qualifies as an antique just yet :p
Looks great!
Well, I'm making progress. I still plan on doing some more planting and I have a few LARGE sandstone rocks that I will set, but this is kinda the "look" I was after.
   / landscaped islands/berms... #6
Looks good!
I have done these things in the past and suggest you consider putting down landscape fabric at the ends to keep the weeds down. Just helps with the maint. end of things and keeps it looking the way you wanted. My two cents...
   / landscaped islands/berms... #7
Looks great. I like the little rock detail outlining the base. Man, the land id flat there... do you get dizzy at that higher elevation...:)!
Lloyd
one more......
And today...............
   / landscaped islands/berms... #10
Looks great! What is the brand and color of the retaining wall block you used... and ball park price for same. I am planning on doing some retainng walls on my property, and really like the look of yours.
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
