Rake LANDSCAPE RAKES
   / LANDSCAPE RAKES #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
What is a good landscape rake for the money?
After I get my land disked I will need a rake to help get the roots in a pile. But when the land is complete, I probably wont use the rake unless another hurricane comes.
I need a 6' rake for my tractor. There is a Bush Hog dealer by my house and he has the model LLR 72 for $650 plus tax. I really don't think its worth that much money. Then a little farther down the road there is an LMC implement dealer that has a 6' rake for $525 plus tax. I could go to Tractor Supply and get the Countyline 6' rake for $469 plus tax also, but a guy down the street from my house sells a few implements and has a 6' "Homier" Chinese rake for $470 plus tax.
Any sugguestions?
Thanks,
Travis R
   / LANDSCAPE RAKES #2
About the only advice that I can give you is that you usually get what you pay for. There have been many here that have had problems bending the bar that the tines fasten to, myself included. :eek: If you want advice on which one to purchase, pictures of them would help a lot. Some designs tend to bend easier than others.
   / LANDSCAPE RAKES #4
If it's only for a one time job go to TSC and buy their rake, if you bend it take it back and tell them it's a POS and they will give you a refund. Their rakes are fine as long as you don't hang it up on something solid, it will bend. With a little modification they are as good as any others.
   / LANDSCAPE RAKES #5
Any sugguestions?
Thanks,
Travis R
I would also look at Landpride,woods,and befco rakes.coobie.
   / LANDSCAPE RAKES #6
Landpride builds a rake to endure serious duty and last.
   / LANDSCAPE RAKES #7
I paid about $1400 for my heavy duty 8' Ford rake 21 years ago. What's that in 2009 dollars? None of these light duty under $1000 rakes compare at all with the real heavy duty $1500 to $2500 rakes. As they say you get what you pay for. Besides the frame, the teeth really matter. In a heavy duty the teeth are thick spring steel and vibrate at high speed causing the material to break up and spread. You don't get this from cheap rakes.
I've been using York rakes for over 40 years and I'd trade good teeth for guage wheels any time. I'll also agree that Landpride (in the higher series ranges) makes a good rake.
Andy
   / LANDSCAPE RAKES #8
I got 4 yrs on my KingKutter 6' rake and yes it's got a coulple of small tweaks (bends) here and there, but mostly still straight. I got 4 KK implements and they've held up just fine. bjr
   / LANDSCAPE RAKES #9
I have a Frontier (JD) rebadged Woods that was a lucky find barely used. New, it is in the pricerange that AndyMA is talking about. A couple of the tines are bent because our Colorado property's best crop was rocks. The frame, however, is like new. It is heavy duty thick steel with substantial welds.
The Land Pride looked similar. The farmstore import I looked at was much lighter duty.
   / LANDSCAPE RAKES #10
Leinbach. I haven't abused mine much and this spring add about 160#'s to make it dig in better, but so far it's a nice rake. Built pretty solid I'd say. If it's truly going to be a one time thing I wouldn't spend much money, but if you've got anything to maintain, driveway etc, then spend a little more. I have 500' drive that I find the rake helps to bring the gravel back in from the sides, so the box blade can level everything.
Wedge
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
1985 International X Con Semi (A50514)
1985 International...
VOLVO EC300EL EXCAVATOR (A51242)
VOLVO EC300EL...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Miles,26,126 (A50323)
