Rake Landscape rake with half the tines?
/ Landscape rake with half the tines? #1
Bob_S
Central Ma
JD 4310 hydro, 4wd
I was told that using a landscape rake with alternating tines removed would work quite well as a replacement for a chain harrow for cleaning up the pasture, breaking up manure etc. Anyone had any experience using a rake this way? Thanks /forums/images/graemlins/grin.gif
/ Landscape rake with half the tines? #2
Not really. It is common to vary the number of tines depending on what stuff one is working on. If I have all the tines in my 6' rake, it lets very little through, and I have to stop the tractor frequently to clear it out unless I'm working on stuff an inch or less in diameter. I suppose you could start out by removing 2 of every 3 blades, for coarse dirt clod work, and go to an every other blade situation for finer work. I only use all tines when combing the driveway gravel - probably the optimal way to groom gravel or fine dirt (or a sand trap). That said, a long chain harrow will take large clods, and reduce them to graded dirt, in a pass or 2.
/ Landscape rake with half the tines? #3
Before going through all that effort, try turning the rake around 180 degrees and see if you like the results. It won't tear up the pasture as much, things won't get caught in the tines, and you won't have to spend an hour removing then replacing the tines.
Mark
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
72in. Fine Low Side Skeleton Skid Steer Bucket (A65640)
72in. Fine Low...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
