Landscape Rake to get gravel back onto road?
   / Landscape Rake to get gravel back onto road? #1
Kubota Dave
Va
B2650 HSD
Would a Landscape Rake be the best to move gravel back onto the road? My gravel always ends up on the road edges.
   / Landscape Rake to get gravel back onto road? #2
Try it, post your results
   / Landscape Rake to get gravel back onto road? #3
Dave
They work pretty good for that. Bette than a rear blade for that purpose in my opinion.
Dave
I have tired the rear blade but it just tears up the road crown.
   / Landscape Rake to get gravel back onto road? #6
All I use on my driveway is a landscape rake.
   / Landscape Rake to get gravel back onto road? #7
I have every other tooth removed on my landscape rake. Angled it works really well for moving stone back into the road.
   / Landscape Rake to get gravel back onto road? #8
How do you accomplish this? I have the same problem, my gravel always rolls and accumulates on the edges of the road. But I haven't yet found a good way to drive along and move all that gravel back to the center. A blade makes it worse because half goes to the middle of the road and the other half goes out farther into the grass. Angling the blade doesn't cure the issue. Also, straddling the edge of the road with the tractor just causes the blade to dig in and ruin the edge of the road.
Somebody needs to make an attachment with a brush or roller that is offset from the tractor and will just sweep the gravel back onto the road as you drive right down the center.
   / Landscape Rake to get gravel back onto road? #9
Angle the landscape rake and pull the gravel back onto the road some with each pass.
   / Landscape Rake to get gravel back onto road? #10
I use my rear scraper blade for this. Maximum angle, and tilted aggressively down and forward using the top link. Some does spill to the outside, but very little.
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
