Landscape rake or box blade .. if I had to buy just one attachment ?
   / Landscape rake or box blade .. if I had to buy just one attachment ? #1
botayota
CT River Valley - NH
Kubota L3240Hst
I have a 600 foot hard-pack/gravel driveway that I need to start maintaining. I need to reshape the driveway, loosen up the material. Clean up the edges, pulling in hard-pack/gravel that is off the driveway, and then possibly add new gravel/hard-pack material. If I have to buy just one of these attachments to maintain my driveway which would you recommend and why? A landscape rake or a box blade
Cheers,
Clint
   / Landscape rake or box blade .. if I had to buy just one attachment ? #2
A box blade. A box blade can do all of the things mentioned, namely reshape the ground where needed (cut and fill) and manage new material. The rake can't do either of those. It's a great tool but different application than you listed.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #3
Agree with JD that the box blade would be the better choice. The landscape rake is great for shaping looser material but when you say hard packed the rake will do little to help that. Also when you look at box blades remember weight is your friend.
MarkV
   / Landscape rake or box blade .. if I had to buy just one attachment ? #4
What they said, our landscape rake hasn't been used in years, both my brothers and I rely on box blades. I am sure they are handy for some things.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #5
I agree with everybody else. Definitely get the box blade first. I would also recommend a hydraulic top link if you can swing it. They run about $250 or so. You tractor will have to have a hydraulic remote.
The hydraulic top link is not a "must have" item but it sure makes life easier.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #6
I bought one a couple of years ago and wish I had done it sooner, one of the best thing I ever did.:thumbsup:
   / Landscape rake or box blade .. if I had to buy just one attachment ? #7
+1 on the box blade. It's what I use for that job at my place.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #8
OK, I'll be the lone rake advocate. I have a 600' gravel driveway which I maintain with my Landpride rake with gauge wheels and flip-down blade. Works pretty good, but I do make many passes. Not saying it's better than a box blade, it's what I got.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #9
I'll throw another fly in the ointment and suggest you not ignore a good rear blade. Find a good, used, heavy-duty one with angle hydraulics and you might find it as useful, if not more than a box blade. It's wider, more versatile, usually cheaper and covers more ground.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #10
Cheers,
Clint
IMO...To use either of these attachments efficiently no less than a hydraulic top-link is paramount...a tilt cylinder would add even more effectiveness... having both greatly reduces the steepness of the learning curve of either a BB or a LR...
IMO...If you have never used either one of the cited attachments... you will find the box-blade takes a some time to learn to use effectively (and get the desired results)...The landscape rake (with at least a HTL) will make you look like an old pro practically the first time you use one...
If I could only have one attachment (non-PTO powered) it would be hands down a box blade....However, considering everything you have said...I would recommend the landscape rake (as wide as possible)...my reasoning (considering your needs) I would suggest renting or borrowing a box blade to do the initial rework phase...Then you will have the rake to use whenever the drive needs some cosmetic dressing or gravel re-distribution...which is much more frequent than re-works...
Don't underestimate what all you can do with a good quality rake (especially with T&T)... besides just the smoothing out effect a rake gives you...it can also be used for many tasks that most experienced users would use their BB for...but with a much less "final product" appearance...
If you have the time to do a lot of shopping you can most likely find both a used BB and LR of viable quality for less than a single brand new one (brand names)...
Good Luck...
   / Landscape rake or box blade .. if I had to buy just one attachment ? #11
For driveway maintenance I would get the boxblade first, the rearblade second and the landplane third. I would get the landscape rake if I had other uses for it besides the driveway work. All of these tools are useful and important to have imo.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #12
i have a long trail with small stone that need to be replaced i own a bb and rake - i use the rake each time - i dump stone in piles along the trail and the rake works great spreading - the bb can't do that
   / Landscape rake or box blade .. if I had to buy just one attachment ? #13
It isn't that you can't spread with a boxblade but it does take skill and seat time to get good results. When I first started out with a boxblade I often made a big mess out of a little problem. Now with seat time, topntilt hydraulics, hydrotransmission and a good boxblade I can get good results.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #14
In my opinion, if the driveway has already been installed, then I think think the Land Plane would be the best tool. While I do not have a box blade, I did have a landscape lake just for maintaining the driveway.
It did not work as the gravel was too hard packed. The rake just bounced over the gravel. Even when I put weight on it.
I picked up the Land Pride Grading Scraper ( Land Plane ) and I can't believe how easy it is to use. I have done the driveway twice with great results. 2 weeks ago, we had 5" of rain over 4 days & a good portion of the driveway washed out due to a drainage problem. I was able fix the whole area within an hour.
This past weekend, I I had a job where I had to bring back 2 parking lots and 2 roads back to good condition. The scarifIers really ripped in to the lots. They were like concrete. I have gotten proficient enough to be able to put a crown back in to the roads to help with the drainage.
The more I work with this tool, the more I am impressed with it.
I agree that if you are moving a lot of material, the box blade is the way to go. But if you are just maintaining and fixing a driveway, I don't think the land plane can be beat.
I also think it is important to have the scarifiers, as this allows you to rip up really hard packed surfaces.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #15
What is the general rule of thumb for width? My rotary cutter is 60" and is the same width as my tractor. Would I want a box blade wider yet or would 5' be okay?
   / Landscape rake or box blade .. if I had to buy just one attachment ? #16
I think it is best to get something that will at least cover your tracks. You can certainly pull one that is not as wide, but it will be a headache when trying to grade anything other than stone. Some guys like to go a little wider than their wheel base. If you do that, just remember that your tractor will fit between things that your blade won't. Being reminded of that the hard way can really hurt your neck; not to mention damage trees and other structures. My tractor is just under 68 inches wide and I went with a 72 inch box blade. I have the HP to pull something wider, but haven't found myself wanting more than what I have. It has been a great combo for me.
   / Landscape rake or box blade .. if I had to buy just one attachment ? #17
Pretty much what crazyangel said. I go quite a bit wider on my box blade than my tire width, but in the woods keep an eye on the rear view mirrors. I have pulled a 10' rotary cutter for years and am use to things sticking out which helps. I am on open areas a lot more than in the woods.
Wow!! thanks guys for all the replies... looks like a box blade would win out as long as I knew how to use one properly, versus a landscape rake which could do some of my driveway work
without alot of seat time. Having the toptilt hydraulic link seems like a plus... luckily I have two spare rear hydraulic outputs I had installed when I bought the tractor so hopefully I could use one
of those for the toptilt link. Will do some further research, and talk to my local tractor guy.
Cheers,
BY
   / Landscape rake or box blade .. if I had to buy just one attachment ? #20
I will agree with "boxblade" for your first choice. And I will add that you should search for a single section drag (harrow) to drag up and down with your garden tractor to keep the grass from growing and to give the gravel a perfect finish. The drag would be used to polish, between sessions of fillng holes and reshaping with the boxblade, OR use the drag following reshaping with the boxblade. I own a boxblade, and landscape rake, and a drag section, and my choice, if the drive is not in too bad of shape, is to use the drag. I use and suggest the garden tractor because it is way more manueverable than your CUT, and can turn around on the dirveway pulling the drag, and can generally fit better in the small areas between buildings, etc. My 2 cents...
2008 CAT 305C (A53317)
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERPILLAR...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
