Landscape Rake on my FEL
   / Landscape Rake on my FEL #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
I need to do some regrading close to our foundation before I dig some new drainage trenches, including ones to dump the downspouts into. The mucky clay fill is kind of a pain to back drag with the FEL bucket, being so damp with all the rain we've been getting. I have to get this project done before the spring rains really set in, so I don't have the luxury of waiting and HOPING the clay dries out.
I wanted the ability to work the rake with a bit more precision than I would get with the 3pt hitch. I figured the loaded rears would end up making a mess up close to the house, and probably trashing the landscaping I'm trying to keep intact. With the rake sitting so far out from the front tires, I can keep the machine further away from the foundation too.
After looking things over, I decided to remove the upper 3pt hitch mount from the rake to lighten it up a bit, and then use 2 existing bolts on the rake frame to attach to the pallet forks (already had holes drilled at the tips). It only took me 30 minutes to set up.
I wouldn't use this particular setup for any heavier duty or higher speed work, but for this type of light duty precision back dragging, it's working out great.
20210119_190336.jpg 20210119_190358.jpg 20210119_190419.jpg 20210119_152409 1.jpg
  • Good Post
Reactions: JWR
   / Landscape Rake on my FEL #2
You made a tool to improve the job. Sounds like you know the limitations and see a better way to get the results you want. Nice job!
   / Landscape Rake on my FEL #3
   / Landscape Rake on my FEL #4
I bought a SSQA adapter for $200 that lets me put 3 PH attachments on the FEL. I mount my rake and back blade and it works for light duty work. I plow light snow falls that the blower will not handle well with the blade. The rake is handy for scratching up soil before overseeing. Works for moving plies of leaves too.
   / Landscape Rake on my FEL #5
Looks like the landscape rake on the FEL would also work great for pulling trash out around the edge of a pond.
  • Good Post
Reactions: JWR
   / Landscape Rake on my FEL #6
I have this old 6' landscape rake. Removed the Cat0 3 point frame and use it in a receiver hitch:
   / Landscape Rake on my FEL #7
This is a similar arrangement, used for ditch cleaning, but it's a blade on a rear loader.
Bruce
   / Landscape Rake on my FEL #8
Awesome idea, bolting the rake to forks. I'll be modifying mine like you did PDQ! Thanks for the tip.
   / Landscape Rake on my FEL #9
EZ loader trailer (A56857)
EZ loader trailer...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
