Rake landscape rake for my bx2230
   / landscape rake for my bx2230 #1
dexter
I am new at this. Will any landscape rake fit my bx2230? Thanks for any help..
   / landscape rake for my bx2230 #2
I use to have a seven foot that would mount OK but was useless to try to use. A five foot would probably work well.
mark
I was told that only rakes made for subcompacts would work since other rakes would not lift high enough with the bx being lower to the ground ?
   / landscape rake for my bx2230 #4
Dexter,
I've got a 6' rake on my 2210. Yeah the lift height is a little low, and you'll most likely drag the ground crossing ditches, but otherwise it works fine. I use it often.
Thanks, To get a little extra height on the BX's lift, I was thinking about drilling a few extra holes in the lift arms. Did anyone ever try this?
Dex
   / landscape rake for my bx2230 #6
Dexter,
I'm guessing the 2210 and 2230 are about the same machine. I'd think you'd want to go longer, not shorter, on the 3 point arms for more height. You do gain lift height by shortening the top link, but it does change the angle of attack of the tines. Unless you've got some really rugged terrain, you should find some setting that works for you.
Joe
   / landscape rake for my bx2230 #7
dexter,
A poster named Henro came up with a pretty decent solution to the problem. He drilled new wholes higher up in the bottom clevis of the lift arms. He got a few more inches of lift this way. I am also told that using any type of quick hitch will also provide more lift height as they effectively lengthen the lift arms.
   / landscape rake for my bx2230 #8
I have 2 extra holes in the lift link shackles and the lower arms @ 0.75" O.C.
ABI TR3 LOT NUMBER 147 (A53084)
ABI TR3 LOT NUMBER...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
