Landscape Rake - First time building anything
   / Landscape Rake - First time building anything #1
kwolfe
Platinum Member
Central PA
Attached are pictures of the rear blade I bought used about 6 months ago (now that I have seen others this one looks homemade). It works well for plowing snow, however has sat idle since I bought a box blade.
Since I have spent more money on a tractor than my wife would like to ever admit, I have limited funds for other implements. This is why I am coming to you all for your suggestions.
Attached are four pictures of my rear blade. As you can see, the blade has a 1" spindle that is welded to the extending arm. The spindle has been drilled and uses a 1/2" bolt to hold the blade on. Taking out that bolt should let the blade drop right off.
I have done a lot of research and am planning on using 3" by 3" by 1/4" angle to attach 30 tines (making the rake 5') to. In order to attach it to the spindle, I was thinking of welding 2" by 2" square to the front of the angle. I would then drill a hole down through the tube for the spindle. Finally I was think of welding a plate on the top of the whol gismo with holes drilled in it so I can angle the rake.
By the way, the spindle seems a little short. It only extends between 2 and 3 inches down from the extension. I was think about cutting it off and drilling for a new one. Not quite sure it is worth it.:confused:
OK, I will stop ramble and wait for you comments. Please don't worry about offending me. If you have better ideas, I am all ears. :D
:) Duh, I forgot to ask. I am thinking about using the two hole tines from Agri-Supply however buying th one hole ones would save me about $30. What are your thoughts on this as well. Thanks again.
   / Landscape Rake - First time building anything #3
Forget the 1-hole tines. Unless you put in some type of spacer between the tines they will rotate. Get the 2-hole and mount them 2" on center. That is what I used on my home made rake. I would suggest using 4" x 4" x 1/4" angle as that is a little more heavy duty with less flex and gives more room for mounting holes. Woods uses this for their rakes. I used a 5" x 1/2" flat bar for mine.
Now that you mention it, you are right. 4" would be better. Do you think I should ditch the existing spindle and replace it with a high grade 1"+ bolt? It would be easer to replace if something bent. I am also going to rework the way the blade hooks up next fall. The current design stinks.
   / Landscape Rake - First time building anything #5
If I recall correctly, I used 7/8" or 1" grade 8 bolts. Expensive but they work fine.
If you are going to use angle instead of flat bar be advised that the angle will bend. About 2 years ago another poster brought a Woods rake into my shop for straightening. It seems he backed into something and bent the heck out of the angle. I ended up re-straightening the angle and adding braces to prevent further damage. I posted a thread about this over a year ago.
I was thinking 1" grade8. I was planning on getting extra angle in order to put a 2" box brace every 12" or so. I think that should be plenty strong for my bx1500.
   / Landscape Rake - First time building anything #7
As you can see from my earlier pictures, I welded a length of 3" angle on the back of the 4" angle and then added a piece of 3" flat bar to the inside of the rake. This was done to both ends of the rake. This was for a B2910 and it doesn't matter what size tractor you have, the rake can still bend if hit just right with the right amount of force.
I just bought 30 tines from Agir-Supply. The total with delievery came to $113.70 delivered to PA. I am planning on making the rake 5", so the tines will be 2" on center. I am going to the scrap yard tomorrow to pick up the angle iron I need. I am taking Mad's advice and going with 4"x4" angle. Looks like I'll be drilling 60 holes very soon.
The existing blade set up I am using has a 1" steel rod that is welded to the frame. I would like to replace it if possible. I do not have a welder, or drill larger then 1/2" at home and the piece is to big to bring into the shop at work. Should I just try and use the existing spindle. I was going to replace it with a 1" grade 8 bolt.
   / Landscape Rake - First time building anything #9
Crap. I should have warned you about paying an arm and a leg for shipping. If you would have broken the tine order into 2 orders of 10 the shipping would have been way less. I got 36 tines and saved a bundle on shipping by using 2 orders.
   / Landscape Rake - First time building anything #10
I got lucky, I searched out previous posts on landscape rake construction and hit Mad's tip on splitting the order up, thanks Mad.
2015 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
Epic Electric Cart (A51694)
Epic Electric Cart...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
2018 International Durastar 4300 Forestry Chipper Bucket Truck (A51692)
2018 International...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
