Rake Landpride york rake attachment?
   / Landpride york rake attachment? #1
ELMO67
CT.
KUBOTA L3010
Greetings- 2nd. time posting, but a long time lurker. I have a Landpride 84'' rear scraper blade, and I need a york rake. Is it possible to get (cost effective?) just the rake attachment and swap it with the blade- maybe by removing just the nut from the main pivot, removing the blade and replacing it with the rake?
   / Landpride york rake attachment? #2
I don't know if its possible to purchase just the rake portion, but it sure is a good idea.
   / Landpride york rake attachment? #3
Elmo,
It is entirely possible. It does swap out just exactly like you said. I have the 72" version and checked into it. The rub is the cost effective. Just the rake head was $525 or so. I thought that a bit extreme when just the blade was $450 or so. I opted to pass. Been admiring the First Choice rakes though.
Added note: After admiring the FC rakes, something to consider is they might just be a 1 for 1 bolt on or limited mod required to work with a LP 3ph frame. Would be much cheaper than the LP version. If you go for it, let us know.
I even had a guy willing to go almost 1/2 way with me. But I have VERY limited needs, and what with bldg a garage, it still wasn't worth it.
Nick
   / Landpride york rake attachment? #4
Why not? It would be no different than buying a replacement part. get the model # of the whole rake assembly you want and have the parts department get the part # off of the computer for the rake and order one. Sometimes buying parts seperatly the prices seem high. Good luck.
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2008 Jeep Patriot Sport SUV (A50324)
2008 Jeep Patriot...
2015 CATERPILLAR D6T XL HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
