Rear Blade Landpride RB3596 rear blade too much for JD4500?
   / Landpride RB3596 rear blade too much for JD4500? #1
RandyK
North Missouri
John Deere 4500
I have a Landpride RB1572 rear blade now which is too small for my JD4500 (I had it with my 790). My tread width measures about 6 foot wide (turf tires), HP is 39, tractor is 4wd, and weighs about 3300 pounds without the loader installed (I have the loader). I think I would need an 8 footer to cover my tracks and I want a blade with the tilt option.
Is the Landpride RB3596 too much for my tractor? The blade weighs about 534 pounds. If I went down to a 7 footer I don't think it would cover my tracks on a moderate angle.
My main purpose for the blade is maintaining about a 300 foot driveway and a small campground including creating/maintaining drainage ditches around both.
If someone has a better option, I'd be glad to hear it.
Thanks!
   / Landpride RB3596 rear blade too much for JD4500? #2
I have a RB3596 on a 41hp Allis-Chalmers tractor now and have ordered a JD3720. I don't think you will have any problems. I have added about 150 lbs of lead to my blade for even more weight. It works great and I am very pleased with it.
   / Landpride RB3596 rear blade too much for JD4500? #3
I went with the Frontier RB 1172 which is same as Woods HBL-72. The 84 would be nice to cover tracks, but a 72 does a nice job and the offsettable hitch allows me to hang hard past one side. I think the 84 would be a bit big for my use.
I've also used this blade on a 4710 and in the snow it doesn't take a lot to veer off course and spin the tractor around in circles with this blade...
   / Landpride RB3596 rear blade too much for JD4500? #4
I run over the snow and drag it and I also grade my 3/10 mile dirt drive with it tilted and offset. I have never had a lick of problems. I dont push with it.I sure hope the 3720 can handle it.
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2013 Land Rover Range Rover Sport (A51694)
2013 Land Rover...
Deere 331G (A50123)
Deere 331G (A50123)
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2003 Ford F-250 Knapheide Service Truck (A51692)
2003 Ford F-250...
2018 Mitsubishi Eclipse Cross SUV (A53117)
2018 Mitsubishi...
