Rotary Cutter LandPride deck issue
/ LandPride deck issue #1
unbidden
R.I.
Kubota BX2660
I have a LandPride FDR 1560 mower deck. Every 10 seconds or so I get a loud buzzer like sound/vibration. The noise is similar to the wrong answer buzzer on Family Feud. I've greased all joints and replaced the belt, belt tension is good. Is it worn bearings?
I know I left myself open for a few chuckles with Fam Feud analogy... what's life without a few laughs ;-)
/ LandPride deck issue #2
Ill pass on the jokes that come to mind including the ones about bees, etc. Take the belt off and spin each spindle and the idler pulley. They should all spin free and smooth. If there is any roughness you have found your problem. Most likely camdidate is the idler pulley.
Thanks OTF. After checking things per your advice I believe you are spot on.
2012 Ford F350 Truck (A62679)
2012 Ford F350...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
30x57 Welding Table (A65640)
30x57 Welding...
