Rotary Cutter LandPride deck issue
   / LandPride deck issue #1
unbidden
R.I.
Kubota BX2660
I have a LandPride FDR 1560 mower deck. Every 10 seconds or so I get a loud buzzer like sound/vibration. The noise is similar to the wrong answer buzzer on Family Feud. I've greased all joints and replaced the belt, belt tension is good. Is it worn bearings?
I know I left myself open for a few chuckles with Fam Feud analogy... what's life without a few laughs ;-)
   / LandPride deck issue #2
Ill pass on the jokes that come to mind including the ones about bees, etc. Take the belt off and spin each spindle and the idler pulley. They should all spin free and smooth. If there is any roughness you have found your problem. Most likely camdidate is the idler pulley.
Thanks OTF. After checking things per your advice I believe you are spot on.
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
Case IH Precision Disc 500T (A50120)
Case IH Precision...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
3 pt AerWay (A50514)
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
