Rear Finish Mower Landpride 1560 Finish mower
   / Landpride 1560 Finish mower #1
wchp14
Garnett
Ford
I recently bought a new Kubota B 2650 and also bought a used Landpride 1560 finish mower off craigslist but I keep breaking belts
The guy said he replaced the belt end of last season but it broke after 1 mow, I bought a replacement belt (Not an official landpride belt) off amazon for $20 and now I have broke that after 2-3 mows.
Everything is greased and looks fine but the tension pulley seems to shake an incredible amount when I have the tractor running at 540+- RPM,
Is this the sign of a bad bearing or do I need to just fork out $90 and buy a landpride belt?
Thanks for any help this is my first rear finish mower and so far I love the way it cuts the grass just concerned about breaking belts so quick
   / Landpride 1560 Finish mower #2
You don't have to buy a Landpride belt, but you should buy a belt constructed with Kevlar, like the Landpride belt is.
   / Landpride 1560 Finish mower #3
I'd bet that you've got a bad bearing or an alignment problem somewhere in there, could even be a bad pulley. With the belt off, it doesn't take long to check the bearings for any play, just a few minutes more to check alignment with a good straightedge and hardly anytime at all to run a finger around the pulleys to check for rough or high spots.
+1 on the kevlar belt
   / Landpride 1560 Finish mower #4
How heavy/thick grass are you cutting?
On my Woods 5' finish mower, I quit cutting heavy weeds or thick grass. I broke two belts before I realized it was a "finish mower" not a "bush hog". :2cents:
   / Landpride 1560 Finish mower #5
Cheaply made low-buck belts aren't gonna last on a finish mower under any but the most gentle circumstances. Looking everything over is good practice, but don't panic if everything checks out OK.
378811 (A51573)
378811 (A51573)
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
SAMSUNG SMART REFRIGERATOR (A51248)
SAMSUNG SMART...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
FRONTIER WR3212 LOT IDENTIFIER 54 (A53084)
FRONTIER WR3212...
