Rear Finish Mower Landpride 1560 Finish mower
   / Landpride 1560 Finish mower #1
wchp14
Garnett
Ford
I recently bought a new Kubota B 2650 and also bought a used Landpride 1560 finish mower off craigslist but I keep breaking belts
The guy said he replaced the belt end of last season but it broke after 1 mow, I bought a replacement belt (Not an official landpride belt) off amazon for $20 and now I have broke that after 2-3 mows.
Everything is greased and looks fine but the tension pulley seems to shake an incredible amount when I have the tractor running at 540+- RPM,
Is this the sign of a bad bearing or do I need to just fork out $90 and buy a landpride belt?
Thanks for any help this is my first rear finish mower and so far I love the way it cuts the grass just concerned about breaking belts so quick
   / Landpride 1560 Finish mower #2
You don't have to buy a Landpride belt, but you should buy a belt constructed with Kevlar, like the Landpride belt is.
   / Landpride 1560 Finish mower #3
I'd bet that you've got a bad bearing or an alignment problem somewhere in there, could even be a bad pulley. With the belt off, it doesn't take long to check the bearings for any play, just a few minutes more to check alignment with a good straightedge and hardly anytime at all to run a finger around the pulleys to check for rough or high spots.
+1 on the kevlar belt
   / Landpride 1560 Finish mower #4
How heavy/thick grass are you cutting?
On my Woods 5' finish mower, I quit cutting heavy weeds or thick grass. I broke two belts before I realized it was a "finish mower" not a "bush hog". :2cents:
   / Landpride 1560 Finish mower #5
Cheaply made low-buck belts aren't gonna last on a finish mower under any but the most gentle circumstances. Looking everything over is good practice, but don't panic if everything checks out OK.
2022 KUBOTA SSV75 SKID STEER (A51246)
2022 KUBOTA SSV75...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53472)
2023 NEW HOLLAND...
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
1065 (A53342)
1065 (A53342)
40ft High Cube Shipping Container (A51573)
40ft High Cube...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
