landpride 15 series post hole digger.
   / landpride 15 series post hole digger. #1
lawn_king
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
Greetings gentlemen. my wife decided we need a fence, a long one 200+ feet. Im not gonna dig post holes by hand, Looking for reviews on the landpride 15 series phd. Is the storage stand worth the money, they don't look like easy implements to hitch up? Thankx in advance.
   / landpride 15 series post hole digger. #2
For your machine and mine a 15 series is fine. I bought the stand but is kind of pricey.200.00$ You can also hang it in a barn or something like that. Mine is on a skid with wheels to move to my tractor instead.
   / landpride 15 series post hole digger. #3
I feel your pain, we are going out today to put in 300+ feet of cross fencing today. And an auger is low on the list of implements so mine go in by hand. Luckily only every 3rd post is wood.
   / landpride 15 series post hole digger. #4
I have one and it's a good PHD. As far as storage, suspend it from a rafter, tree limb or sink two poles and add a cross bar to suspend it from.
   / landpride 15 series post hole digger. #5
less than $30
Can i use this unit on both my tractors or does the pto shaft have to be cut to fit one particular machine?
   / landpride 15 series post hole digger. #7
You'll just need to check it. It will probably work between the two.
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
toro turf sweeper (A50324)
toro turf sweeper...
2023 Kubota U27-4 (A50120)
2023 Kubota U27-4...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
