Land Pride RCR2596 and 2510 Rotary Cutter Questions
   / Land Pride RCR2596 and 2510 Rotary Cutter Questions #1
leeave96
Central Western VA
Wheelhorse 520H & 314-8
Anyone run a Land Pride RCR2010 (10ft) or RCR2596 (8ft) rotary cutter? Manual says 1.5 inch max cut - sounds like a light duty cutter, which is OK.
Anyone have one of these mowers and how is it holding up?
Thanks!
   / Land Pride RCR2596 and 2510 Rotary Cutter Questions #2
Hi leeave96, I have a RCR2010 I bought new around 7-8 years ago. It’s a great cutter, I’ve had zero problems with it. Leaves a really nice, clean cut. It is rated at 1.5” diameter max cut, I try to not exceed that but I will tell you it is a very heavy cutter to be rated “light duty”. Any other specific questions, let me know. I’ve pulled it with a 52 hp JD and a 75 hp NH. I don’t think you’d want to go under 50 horse to pull it.
It is a bear to grease with all the shields. I cut some 1 inch or so holes in the plastic shields in a couple places to access the grease zerks easier. Good luck !
Thanks!
I appreciate the info.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2024 Wacker Neuson ST31 (A50120)
2024 Wacker Neuson...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
2012 Hyundai Sonata Sedan (A50324)
2012 Hyundai...
Ran during check in. No longer running. (A51694)
Ran during check...
2007 Ford Ranger Ext. Cab Pickup Truck (A50323)
2007 Ford Ranger...
