Land Pride RCR2596 and 2510 Rotary Cutter Questions
   / Land Pride RCR2596 and 2510 Rotary Cutter Questions #1
leeave96
Central Western VA
Wheelhorse 520H & 314-8
Anyone run a Land Pride RCR2010 (10ft) or RCR2596 (8ft) rotary cutter? Manual says 1.5 inch max cut - sounds like a light duty cutter, which is OK.
Anyone have one of these mowers and how is it holding up?
Thanks!
   / Land Pride RCR2596 and 2510 Rotary Cutter Questions #2
Hi leeave96, I have a RCR2010 I bought new around 7-8 years ago. It’s a great cutter, I’ve had zero problems with it. Leaves a really nice, clean cut. It is rated at 1.5” diameter max cut, I try to not exceed that but I will tell you it is a very heavy cutter to be rated “light duty”. Any other specific questions, let me know. I’ve pulled it with a 52 hp JD and a 75 hp NH. I don’t think you’d want to go under 50 horse to pull it.
It is a bear to grease with all the shields. I cut some 1 inch or so holes in the plastic shields in a couple places to access the grease zerks easier. Good luck !
Thanks!
I appreciate the info.
2019 Harley Davidson (A56859)
2019 Harley...
UNUSED WOLVERINE TD-13-36R 36-48" TREE DIGGER (A57193)
UNUSED WOLVERINE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A57192)
UNUSED INDUSTRIAS...
2015 Ford F-350XL (A53317)
2015 Ford F-350XL...
2024 Deere 333D (A53317)
2024 Deere 333D...
