Rotary Cutter Land Pride RCR 2596 greasing issues
   / Land Pride RCR 2596 greasing issues #1
Buzman
Farmall 75c
I just purchased a new Land Pride RCR 2596 rotary cutter. I have an issue with greasing the PTO universal joint next to the cutter. The shields make it impossible to reach the grease fitting. The dealer where I purchased it said "do whatever you like." I am thinking of either removing the offending safety shield or taking my rotozip and zipping off a large chunk of the bothersome shield.
I look forward to input on how others have handled greasing this PTO knuckle.
   / Land Pride RCR 2596 greasing issues #2
I unbolt the shaft from the mower (not a Land Pride). The PTO guard on the mower has small doors to be used to get to the retaining bolt.
Removing the shaft lets you bend the u joint to get access to the grease fitting in the center. Most of the u joints I've seen on PTO shafts would be hard to grease without doing that.
   / Land Pride RCR 2596 greasing issues #3
Buzman, I have the RCR2510 model, bought new. I had the same issue it is a bear to grease. Spoke to my dealer and he basically said the same thing yours did. I cut 2” holes out of the shield with a Dremel, along with a Lock n Lube on my grease gun and a 90 degree push on grease fitting attachment I can grease the cutter in 15-20 minutes now. I do remove the top shield on top of the cutter between the gearboxes to make things easier too.
It’s a great cutter, I just don’t understand why Land Pride makes such an important maintenance item so difficult. Enjoy your new cutter!
   / Land Pride RCR 2596 greasing issues #4
Just to clarify: when I say “remove the top shield” I mean the steel cover between the gearboxes, and replace it of course before use.
   / Land Pride RCR 2596 greasing issues #5
I have a Titan cutter with the same issue. I also have a 1" hole drilled in the plastic safety cover and also use a 90 degree attachment on my grease gun. It sometimes gets messy, but it works. 2" holes would probably give better access.
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
