Rotary Cutter LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS?
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I recently purchased a LAND PRIDE - RCF 2060 Rotary Cutter ($1,600) to pull behind my Kubota L3560.
Land Pride supplied CHEAP Draw Pins are too short to get a boot on, and ROLL PINS for finger grips?
How many customers buying a RCF 2060 will retain the cheap Draw Pins? Approximately zero, I should guess.
WHY SUPPLY INADEQUATE DRAW PINS FROM THE FACTORY ??????
Photo #3 shows ample/generous/over-spec Draw Pins supplied with HOWSE Disc Harrows.
LAND PRIDE: There is no such thing as PARTIAL excellence.
This is my first implement from LAND PRIDE.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #2
Them are pretty cheap pins. I bought a Land Pride rear blade last fall and it is very well built and has very nice cat 1 & cat 2 combo pins. Maybe somebody swapped pins on the dealer lot?
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #3
Same as Underdog57 only I bought my RCR2672 three year ago and it had very good cat 1 and II pins.
According to the Kubota mechanic, who unloads the trucks, that is the way Land Pride RCF 2060s arrive.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #5
I had those junk pins on my Shredder too. Jeff wants me to say" Land Pride Shredder too"
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #6
Those look like the same too-dang-short-pins that come on LP's landplanes.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #7
Now the Pins on my Land Pride Landplane were alright.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #9
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #10
If the pin fits the hole and fits the hitch and carries the load, it doesn't seem like a big issue to me....unless I don't understand something here....:2cents:
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2013 MACK CXU (A52472)
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
