Rotary Cutter Land Pride RC1548 4' Rotary Cutter Shear Pin
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #1
Howard92
South Pittsburg, Tn
B2920 Kubota, GT275 Deere
I have a Land Pride RC1548 rotoary cutter on a B2920 Kubota. It's all brand new and I've never used the rotary cutter. I pulled the shear pin out to see what size/type it was. It looks like a 3-1/2" long 1/2" dia bolt with no head markings. I assume its a grade 2.
Should I go back to the dealer to get some spares? Or can I just use off the shelf grade 2 bolts as replacements?
Thanks for any help,
Howard
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #2
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #3
Howard
Just wanted to say that I think that's a really good mower, I had one when I used to have my JD750. I bought it used and got great service out of it for the few years that I owned. I think the previous poster gave you great information on the shear bolt. Good luck with it!
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #4
Standard bolts are usually grade 5. You'll like have to get grade 2 bolts at a dealer. If you can't find grade 2 machine bolts easily you may be able to use carriage bolts, some of which are often grade 2.
I had a hard time finding 5/16" grade 2 bolts for my snowblower, even at dealers. My rotary mower uses 1/2" grade 2 bolts which were easier to find at a dealer.
24. 802-264C HHCS 1/2-13X3 1/2 GR2 For shear bolt PTO only
Thanks for the info. I have the printed owners manual and had actually found that part and read it. But I didn't know the "GR2" meant grade 2.
Thanks again for help and schoolin',
Howard
Thanks for the info from your experience. I bought it mainly to mow/clear in the woods; so I wanted something pretty small that I could get through the trees.
Thanks,
Howard
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #7
You should be able to buy grade 2 bolts at Lowes, Tractor Supply or a hardware store. I have seen some shear bolts (mainly in snowblowers) that are 5/16" and the have a groove in cut in them to make them 1/4'', like these here. If it is just a regular bolt a hardware store bolt should work fine.
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #8
I had the 60" version, I always used off the shelf unmarked bolts, worked great. Broke LOTS of them!
   / Land Pride RC1548 4' Rotary Cutter Shear Pin #9
Yes, the unmarked bolts are grade 2, 3 dashes = grade 5, and 6 dashes = grade 8. I found it very difficult to find 5/16" grade 2's for my three point snowblower at local farm equipment dealers, big box hardware stores, and local bolt specialty shops. I finally found them online at a wholesaler and through their dealer list got them at the one local farm equipment store I had not checked. Part of the difficulty was the 5/16" size that I gather is relatively uncommon as opposed to say, 1/2".
My local big box stores such as Rona, Home Depot, Cdn Tire, Home Hardware, mainly sell grade 5 and perhaps some grade 8's. Even the local fastener stores(BC Fasteners, Bolt Supply in Calgary, Acklands) here don't seem to carry grade 2's.
Here's a table showing shear strengths:
View attachment Bolt_Shear_Strength.pdf
The 1/2" grade 2 bolt the OP mentioned has a shear strength of 8,717.5 lbs. while a grade 5 bolt's shear strength is 14,136.5 lbs.
Last year my neighbour "temporarily" used a grade 5, 5/16" bolt in a blower like mine instead of a grade 2. The result was a bent auger after picking up a rock. He is a machinist and was able to fix the auger on his press.
The main point is to use the size and grade shear bolt the manufacturer specifies.
FAKE (A52472)
FAKE (A52472)
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
