Land Pride RB3796 vs. RBT3596
/ Land Pride RB3796 vs. RBT3596 #1
MMH
Murrysville, PA
JD 4500
What is the difference between a RB3796 and a RBT3596? Seems like the RBT is set up for hydraulics for offset, tilt and angle, but the hydraulics themselves are options while the RB is set up for only the hydraulic angle. The RBT is about 80 lbs. heavier and but I don't know about the difference in cost. What else is different?
/ Land Pride RB3796 vs. RBT3596 #2
/ Land Pride RB3796 vs. RBT3596 #3
The 35 is a fully optioned back blade for all adjustments if not hydraulic they are run by turn buckles. There is about 100 lbs difference in the weight which is a plus not only in the construction but also digging ability. The 35 set up with turnbuckles is about 1,000 dollars more and naturally the hydraulics would be more yet and you could only make one or two items hydraulic vs all three options.
/ Land Pride RB3796 vs. RBT3596 #4
Why only 1 or 2?
The only turn buckle as far as the manual adjusting goes is the tilt function. The blade angle and offset features are a telescoping tube with a pin.
Are you saying that he can only have 1 or 2 because that's all the rear remotes that he may have? :confused: He can always add more remotes. :cool:
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2022 EZ-GO ELITE...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2019 CENTEX TRAILER 18' COOL DOWN TRAILER (A65643)
2019 CENTEX...
