MattM
I just bought a used FDR 1672 finish mower. It looks like the gearbox mount platform is bent slightly, and the drive pulley is not quite aligned with the others. It's as if it were lifted by the gearbox shaft, so now the shaft isn't horizontal, it points up a little. The mount plate unbolts, and has a slot to slide the gearbox out with the pulley attached.
My question is Will the gearbox just unbolt and slide out? If the pulley stays on, are there any oil seals to mess with? Do you think a shop press could flatten the mount plate?
Thanks for any help.
