Box Scraper Land Pride GS1572 vs GS2572 on a Kubota MX5200
   / Land Pride GS1572 vs GS2572 on a Kubota MX5200 #1
Raveric
Marlboro, NY
Kubota MX5200
Hi all. I'm buying my first tractor (a Kubota MX5200) and my first grading scraper. In short, I've got 2 options at present: a Land Pride GS1572 (GS15 Series Grading Scrapers | Land Pride) and a Land Pride GS2572 (GS25 Series Grading Scrapers | Land Pride). I've got about 2000 feet of (currently pretty compacted and rutted out) gravel driveway to maintain.
From where I sit, the core difference between the 2 grading scrapers are:
- 200 lbs
- 1 additional scarifier shank
- a few hundred dollars
I'd spring for the GS2572, but it's on backorder for 2 months... and the GS1572 is available today.
In short, do you guys think I should way for the GS2572, or will the difference be negligible on a ~50hp machine like the Kubota MX5200? I'd love to get my embarrassment of a driveway fixed up sooner than later, but not as much as I'd like to get the right lifetime tool for the job.
Thanks in advance for your input, all.
   / Land Pride GS1572 vs GS2572 on a Kubota MX5200 #2
How about a GS2584? Either way, get a 25 series if you want to stay with Land Pride. Weight is your friend. :thumbsup:
   / Land Pride GS1572 vs GS2572 on a Kubota MX5200 #3
I find my 1572 plenty heavy enough. But don't make the mistake I did and get one too wide! I am finally realizing that in most places my drive is 10ft wide, not 12. It's important that the center-of-the-road skid ride ON the center of the road. Else you risk cutting down the crown.
Anyone around middle TN want to buy a very slightly used GS1572? Or trade for a GS1560?
   / Land Pride GS1572 vs GS2572 on a Kubota MX5200 #4
This is very common. It seems that all the LPGS work pretty good. But if a person was to be able to use both on the same surface, most would find that the heavier unit worked better. Almost like saying that a 600lb box blade works, which it does, but a 900-1000lb+ unit works better. :thumbsup:
   / Land Pride GS1572 vs GS2572 on a Kubota MX5200 #5
I just brought home a GS1560 this week. Before choosing I went and measured the width of my driveway at both narrow and wider parts. Usually right about 10ft wide, with some areas on turns being 12ft.
On the wider sections i plan to have a skid at the outer edge of the road for one pass, then come back over it with inner skid on center.
I went with the 1572. I'll let you now how we fare. Thanks for the advice!
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
36'' Mini Excavator Bucket (A51573)
36'' Mini...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
